Switching Between Connectable Advertising and Beacon Advertising On BLE_GAP_EVT_ADV_SET_TERMINATED
Hi, I have the following code in main.c:
    ret_code_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
						  NRF_LOG_INFO("AVD EVT IDLING");
					switch (advertising_mode_state)
						case 1:          //advertising_beacon
//									sd_ble_gap_adv_stop();
							connectable_advertising_init();
							advertising_start(BLE_ADV_MODE_SLOW);
						case 2:          // advertising_connectable
							beacon_advertising_init();
static void connectable_advertising_init(void)
	  NRF_LOG_INFO("Connectable ADV INIT");
    ble_advertising_init_t init;
	  ble_advdata_manuf_data_t                  manuf_data; //Variable to hold manufacturer specific data
    uint8_t data                              = UNIT_SERIAL; //Our data to advertise
    manuf_data.data.p_data                    = &data;
    manuf_data.data.size                      = sizeof(data);
    init.advdata.p_manuf_specific_data = &manuf_data;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = false;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
		advertising_mode_state = 2;
static void beacon_advertising_init(void)
		NRF_LOG_INFO("Beacon ADV INIT");
	/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = NULL,
        .len    = 0
	static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                         // implementation.
    APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                         // manufacturer specific data in this implementation.
    APP_BEACON_UUID,     // 128 bit UUID value.
    APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
    APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
    APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                         // this implementation.
	  uint32_t      err_code;
    ble_advdata_t advdata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
	    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
		NRF_LOG_INFO("Build and set advertising data");
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    // Initialize advertising parameters (used when starting advertising).
		NRF_LOG_INFO("Initialize advertising parameters");
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
    m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration        = APP_ADV_DURATION;
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
		NRF_LOG_INFO("Encode Finished");
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
		NRF_LOG_INFO("Err Code: %d", err_code);
		NRF_LOG_INFO("Configure Finished");
    advertising_mode_state = 1;
/**@brief Function for starting connectable advertising.
static void advertising_start(bool erase_bonds)
				NRF_LOG_INFO("Entering Connectable Advertising Start");
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
			  NRF_LOG_INFO("Leaving Connectable Advertising Start");
/**@brief Function for starting beacon advertising.
/*static void beacon_advertising_start(void)
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
	  NRF_LOG_INFO("Leaving Beacon Advertising Start");
/**@brief Function for changing the tx power.
static void tx_power_set(void)
    ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
/**@brief Function for enabling the DC/DC Converter.
static void dcdc_enable_init(void)
	sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
/**@brief Function for application main entry.
    bool erase_bonds = false;
    // Initialize.
    log_init();
    timers_init();
//    buttons_leds_init(&erase_bonds);
    power_management_init();
    ble_stack_init();
//		timeslot_sd_init();
		adc_configure();
    gap_params_init();
    gatt_init();
		services_init();
    conn_params_init();
    peer_manager_init();
		dcdc_enable_init();
    // Start execution.
    NRF_LOG_INFO("Service started.");
    application_timers_start();
    advertising_start(erase_bonds);
		tx_power_set();
    // Enter main loop.
    for (;;)
        idle_state_handle();
If I initialize the beacon advertising first, which is the shown configuration, I get fatal error code 8 out of ble_advertising_start.
If I initialize the connectable advertising first, it does time out and as intended and tries to initialize  beacon_advertising_init() in on_adv_event, but fails with err code 4 at sd_ble_gap_adv_set_configure
I think I am really close here -- any thoughts on what I am doing wrong?
