Hi, I have the following code in main.c:
ret_code_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
NRF_LOG_INFO("AVD EVT IDLING");
switch (advertising_mode_state)
case 1: //advertising_beacon
// sd_ble_gap_adv_stop();
connectable_advertising_init();
advertising_start(BLE_ADV_MODE_SLOW);
case 2: // advertising_connectable
beacon_advertising_init();
static void connectable_advertising_init(void)
NRF_LOG_INFO("Connectable ADV INIT");
ble_advertising_init_t init;
ble_advdata_manuf_data_t manuf_data; //Variable to hold manufacturer specific data
uint8_t data = UNIT_SERIAL; //Our data to advertise
manuf_data.data.p_data = &data;
manuf_data.data.size = sizeof(data);
init.advdata.p_manuf_specific_data = &manuf_data;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
advertising_mode_state = 2;
static void beacon_advertising_init(void)
NRF_LOG_INFO("Beacon ADV INIT");
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = NULL,
.len = 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = /**< Information advertised by the Beacon. */
APP_DEVICE_TYPE, // Manufacturer specific information. Specifies the device type in this
// implementation.
APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
// manufacturer specific data in this implementation.
APP_BEACON_UUID, // 128 bit UUID value.
APP_MAJOR_VALUE, // Major arbitrary value that can be used to distinguish between Beacons.
APP_MINOR_VALUE, // Minor arbitrary value that can be used to distinguish between Beacons.
APP_MEASURED_RSSI // Manufacturer specific information. The Beacon's measured TX power in
// this implementation.
uint32_t err_code;
ble_advdata_t advdata;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
// If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
// UICR instead of using the default values. The major and minor values obtained from the UICR
// are encoded into advertising data in big endian order (MSB First).
// To set the UICR used by this example to a desired value, write to the address 0x10001080
// using the nrfjprog tool. The command to be used is as follows.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
// For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
// the following command should be used.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
m_beacon_info[index++] = MSB_16(major_value);
m_beacon_info[index++] = LSB_16(major_value);
m_beacon_info[index++] = MSB_16(minor_value);
m_beacon_info[index++] = LSB_16(minor_value);
manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
// Build and set advertising data.
NRF_LOG_INFO("Build and set advertising data");
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
// Initialize advertising parameters (used when starting advertising).
NRF_LOG_INFO("Initialize advertising parameters");
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = APP_ADV_DURATION;
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
NRF_LOG_INFO("Encode Finished");
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
NRF_LOG_INFO("Err Code: %d", err_code);
NRF_LOG_INFO("Configure Finished");
advertising_mode_state = 1;
/**@brief Function for starting connectable advertising.
static void advertising_start(bool erase_bonds)
NRF_LOG_INFO("Entering Connectable Advertising Start");
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
NRF_LOG_INFO("Leaving Connectable Advertising Start");
/**@brief Function for starting beacon advertising.
/*static void beacon_advertising_start(void)
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
NRF_LOG_INFO("Leaving Beacon Advertising Start");
/**@brief Function for changing the tx power.
static void tx_power_set(void)
ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
/**@brief Function for enabling the DC/DC Converter.
static void dcdc_enable_init(void)
sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
/**@brief Function for application main entry.
bool erase_bonds = false;
// Initialize.
log_init();
timers_init();
// buttons_leds_init(&erase_bonds);
power_management_init();
ble_stack_init();
// timeslot_sd_init();
adc_configure();
gap_params_init();
gatt_init();
services_init();
conn_params_init();
peer_manager_init();
dcdc_enable_init();
// Start execution.
NRF_LOG_INFO("Service started.");
application_timers_start();
advertising_start(erase_bonds);
tx_power_set();
// Enter main loop.
for (;;)
idle_state_handle();
If I initialize the beacon advertising first, which is the shown configuration, I get fatal error code 8 out of ble_advertising_start.
If I initialize the connectable advertising first, it does time out and as intended and tries to initialize beacon_advertising_init() in on_adv_event, but fails with err code 4 at sd_ble_gap_adv_set_configure
I think I am really close here -- any thoughts on what I am doing wrong?
