RGB
Hi
I have a RGB LED and want to have bellow process for brightness:
Red from o to 100 then Green from 0 to 100 and Blue from 0 to 100.
till now i by bellow code i can go for a white color which seems start from 0 to 100. But what i need is different because i am
unable to do it for 3 colors. I will appereciate if u help me. Moreover i am using demo1 of pwm driver example.
 * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup pwm_example_main main.c
 * @ingroup pwm_example
 * @brief PWM Example Application main file.
 * This file contains the source code for a sample application using PWM.
#include <stdio.h>
#include <string.h>
#include "nrf_drv_pwm.h"
#include "app_error.h"
#include "boards.h"
#include "bsp.h"
#include "app_timer.h"
#include "nrf_drv_clock.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define red 31
#define green 29
#define blue 28
static nrf_drv_pwm_t m_pwm0 = NRF_DRV_PWM_INSTANCE(0);
static uint16_t const              m_demo1_top  = 10000;
static uint16_t const              m_demo1_step = 200;
static uint8_t                     m_demo1_phase;
static nrf_pwm_values_individual_t m_demo1_seq_values;
static nrf_pwm_sequence_t const    m_demo1_seq =
    .values.p_individual = &m_demo1_seq_values,
    .length              = NRF_PWM_VALUES_LENGTH(m_demo1_seq_values),
    .repeats             = 0,
    .end_delay           = 0
static void demo1_handler(nrf_drv_pwm_evt_type_t event_type)
    if (event_type == NRF_DRV_PWM_EVT_FINISHED)
        uint8_t channel    = m_demo1_phase >> 1;
        bool    down       = m_demo1_phase & 1;
        bool    next_phase = false;
        uint16_t * p_channels = (uint16_t *)&m_demo1_seq_values;
        uint16_t value = p_channels[channel];
        if (down)
            value -= m_demo1_step;
            if (value == 0)
                next_phase = true;
            value += m_demo1_step;
            if (value >= m_demo1_top)
                next_phase = true;
        p_channels[channel] = value;
        if (next_phase)
            if (++m_demo1_phase >= 2 * NRF_PWM_CHANNEL_COUNT)
                m_demo1_phase = 0;
static void demo1(void)
    nrf_drv_pwm_config_t const config0 =
        .output_pins =
          red | NRF_DRV_PWM_PIN_INVERTED, // channel 0
          green| NRF_DRV_PWM_PIN_INVERTED, // channel 1
          blue | NRF_DRV_PWM_PIN_INVERTED, // channel 2
        .irq_priority = APP_IRQ_PRIORITY_LOWEST,
        .base_clock   = NRF_PWM_CLK_1MHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = m_demo1_top,
        .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
        .step_mode    = NRF_PWM_STEP_AUTO
    APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, demo1_handler));
    (void)nrf_drv_pwm_simple_playback(&m_pwm0, &m_demo1_seq, 1,
                                      NRF_DRV_PWM_FLAG_LOOP);
    demo1();
    for (;;)
