SOFT DEVICE : INVALID MEMORY ACCESS - START CLOCK AND SOFT DEVICE not working together.
Hi!
I am working on NRF 52840 Controller and Soft Device Version 6.0.0. Coding using Keil IDE in C.
Also developing using Free RTOS.
According to the requirement I need to use  a Timer Module as a Counter (through PPI) to cause an interrupt. I am using Timer - 1 ( as Soft Device is using Timer - 0 ).
When I start the High Frequency Clock => " NRF_CLOCK->TASKS_HFCLKSTART "   ,  I am getting INVALID MEMORY ACCESS ERROR.
Soft Device is enabled.
The PPI Channel used is Channel - 0
Please Let me know if I am looking at the right place for this error and also if I am missing any configurations.
ThanksGrinning
 This is the Error Print from the Firmware.;
  • nrf_drv_timer_config_t timer_cfg = NRF_DRV_TIMER_DEFAULT_CONFIG;
            err_code = nrf_drv_timer_init( &m_timer2, &timer_cfg, sample_counter_event_handler );
            APP_ERROR_CHECK( err_code );
            nrf_drv_timer_clear( &m_timer2 );
            nrf_drv_timer_extended_compare( &m_timer2, NRF_TIMER_CC_CHANNEL0, XXX, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true );
         //XXX is the data count we want to ready from the Channel  Register.
            // Configuring the PPI used for automating the data streaming
            err_code = nrf_drv_ppi_channel_alloc( &m_ppi_channel );
            // Set up PPI Chn0 for triggering of SPIM start when DR pin event occurs (set up for falling edge event)
            err_code = nrf_drv_ppi_channel_assign( m_ppi_channel,
                                                   nrf_drv_gpiote_in_event_addr_get( AFE_DR_PIN ),
                                                   nrf_spim_task_address_get( nrfbusHandle->busIdentifier.u.spim.p_reg, NRF_SPIM_TASK_START ) );
            // Fork PPI to also trigger count on timer2 to keep track of number of samples.
            err_code = nrf_drv_ppi_channel_fork_assign( m_ppi_channel,
                                                        nrf_drv_timer_task_address_get( &m_timer2, NRF_TIMER_TASK_COUNT ) );
        nrf_drv_timer_enable( &m_timer2 );
        err_code = nrf_drv_ppi_channel_enable( m_ppi_channel );
    This is the code. The last second line is causing a Problem.
    My code is not executed Further.
    I tried disabling the Soft device also, but the code was still hung.
