NRF_LOG/RTT backend suddenly stops working (SDK15.0.0)
I'm using NRF_LOG to print information via RTT backend (RTT viewer v6.20) and it has been working so far. After adding a single call to a function that reads 128 bytes of data from an RFID tag to a RAM buffer (RFID reader IC over SPI) the logs stop working. NRF_LOGs work fine up to that point. I'm not printing anything or calling any NRF_LOG function when doing this (unless the NRFX spi driver is doing it in the background?). The execution continues normally unless i call NRF_LOG_FLUSH which will hang. I tried to read the RFID tag memory in chunks rather than the single 128 byte read. Doing that and NRF_LOG continues to work even efter the calls, but I end up in other problems with the RFID parts so I can't do this way.
If using Segger_RTT_printf() when NRF_LOG has crashed I will get output so it seems to work at a lower level.
Application is using a softdevice.
I've tried experimenting with various settings of buffer sizes etc for NRF_LOG in sdk_config.h without any luck.
Any suggestion of what might be causing this behaviour or what to check?
BR
//Ola
