BMI160 + NRF52832 + I2C
HI,
I want to develop a program to access Accelerometer and gyroscope value from BMI160 sensor. I have used this BMI160 library
I alter the TWI_SENSOR code and it works for self testing ACC code. but i need to calibrate the x, y, z axis value and i want to add BLE stack to read in mobile app.
1. How to collect all the X,Y,Z axis value
2. i need to see the LOGS in Bluetooth app by using BLE_UART. how to edit the BLE_UART code to get the respective ACC and GYRO value in BLE APP.
Is there any code for reading X,Y,Z axis for BMI160??
    1. There is API in the library you linked for getting sensor data. What have you done to integrate the library in your application? Did you follow the User Guide?
    2. You need to integrate the library in order to get the data first. The data can be sent over BLE using the function ble_nus_data_send().
    Jørgen
  • Then you need to post the code you have implemented in order for us to help your any further.
    You need to implement the SPI/TWI read/write functions for the library to work. It is just a general library and does not know how to interface with peripherals of nRF5x ICs.
  • Hi jorgen,
    In the above function for central . the device will act as central and mobile phone is act as Peer.
    so that when I'm connect to the device that time i need to enable the notification and it will send the data to mobile phone. otherwise its in disable condition.
    Is it right?
    How to add the proximity into my device. that i need to know how much distance between the device and mobile phone  and   the device is in out of range or in the specified range. the LED in the device should blink and mobile phone receive alert notification.
  • Hi Jorgen,
    I need to read the battery value. but with out adc is it possible to read the battery level with internal registers. ?
    If adc is used means can you give any schematic related to ADC connection. It will be helpful for my project.
  • Hey Nordic,
    I'm trying to follow along this thread to create a bluetooth accelerometer project and I just can't seem to get it to work.
    I have tried to follow the instructions as closely as possible.
    #include <stdio.h>
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "bmi160.h"
    /* TWI instance ID. */
    #define TWI_INSTANCE_ID     0
    #define G_TO_LSB (16384.0f)
    #define DPS_TO_LSB (131.072f)
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    /* Indicates if operation on TWI has ended. */
    static volatile bool m_xfer_done = false;
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    struct bmi160_dev sensor;
    struct bmi160_sensor_data accel;
    struct bmi160_sensor_data gyro;
    int8_t rslt = BMI160_OK;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    /*TWI initialization*/
    void twi_init (void)
        const nrf_drv_twi_config_t twi_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
        if (NRF_SUCCESS == err_code)
    		nrf_drv_twi_enable(&m_twi);
    		NRF_LOG_INFO("TWI init success...");
    int8_t Acc_i2c_Write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
        //  NRF_LOG_INFO("WRITE: dev_id: %x reg_addr: %x reg_data: %x len: %i\n", dev_id, reg_addr, *reg_data, len);
    	int8_t rslt = 0;
    	uint8_t data[len + 1];
    	data[0] = reg_addr;
    	for (uint16_t i = 0; i < len; i++) {
    		data[i + 1] = reg_data[i];
    	rslt = nrf_drv_twi_tx(&m_twi, dev_id, data, len + 1, false);
    	APP_ERROR_CHECK(rslt);
            return rslt;
    int8_t Acc_i2c_Read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    	int8_t rslt = 0;
       //     NRF_LOG_INFO("READ: dev_id: %x reg_addr: %x len: %i\n", dev_id, reg_addr, len);
    	rslt = nrf_drv_twi_tx(&m_twi, dev_id, &reg_addr, 1, true);
    	if (rslt == 0)
    		rslt = nrf_drv_twi_rx(&m_twi, dev_id, reg_data, len);
        //    NRF_LOG_INFO("READ: %x",*reg_data);
    	return rslt;
    void Acc_delay_ms(uint32_t period)
    /*if (period==NULL){
    period = 1;
    }// delay time*/
      nrf_delay_ms( period ) ;
    void BMI160_init (void)
        sensor.id = BMI160_I2C_ADDR;         //0x69
        sensor.interface = BMI160_I2C_INTF;  //0x00
        sensor.read = &Acc_i2c_Read;
        sensor.write = &Acc_i2c_Write;
        sensor.delay_ms = &Acc_delay_ms;
        rslt = bmi160_init(&sensor);
        if(rslt == BMI160_OK){
        NRF_LOG_INFO("BMI160 Initialized...");
        } else {
        NRF_LOG_INFO("BMI160 not Initialized...");
        }//NRF_LOG_FLUSH();
        sensor.accel_cfg.odr = BMI160_ACCEL_ODR_1600HZ;
        sensor.accel_cfg.range = BMI160_ACCEL_RANGE_2G;
        sensor.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
        sensor.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
        sensor.gyro_cfg.odr = BMI160_GYRO_ODR_3200HZ;
        sensor.gyro_cfg.range = BMI160_GYRO_RANGE_2000_DPS;
        sensor.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
        sensor.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
        rslt = bmi160_set_sens_conf(&sensor);
        NRF_LOG_INFO("sensor Configured...");
        } else {
        NRF_LOG_INFO("sensor not Configured...");
        }//NRF_LOG_FLUSH();
    static void read_sensor_data()
          uint16_t data_array1;
          static uint8_t index = 11;
          int length1 = 2;
          char* str;
           //err_code = ble_mpu_update(&m_mpu, &accel_values);
          //              APP_ERROR_CHECK(err_code);
          bmi160_get_sensor_data(BMI160_ACCEL_SEL, &accel, NULL, &sensor);
          data_array1 = accel.x;
          length1 = sprintf(str, "ACCX: %5d", data_array1);
          rslt = ble_nus_data_send(&m_nus, &str, &length1, m_conn_handle);
          //APP_ERROR_CHECK(rslt);
          //NRF_LOG_HEXDUMP_DEBUG(str,  index);
          //rslt = ble_nus_data_send(&m_nus, str, &length1, m_conn_handle);
          //NRF_LOG_INFO("DataX:%d", accel.x);
          //length1 = sprintf(str, "Value of AccX: %5d", data_array1);
          //length2 = sprintf(str, "Value of AccX = %5d", accel.x);
          //NRF_LOG_INFO("DataY:%d", accel.y);
          //NRF_LOG_INFO("DataZ:%d", accel.z);
          //NRF_LOG_INFO("GyroX:%d", gyro.x);
          //NRF_LOG_INFO("GyroY:%d", gyro.y);
          //NRF_LOG_INFO("GyroZ:%d", gyro.z);
          Acc_delay_ms(100);
          NRF_LOG_FLUSH();
    /**@brief Application main function.
        bool erase_bonds;
        uint8_t sample_data[10];
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        NRF_LOG_INFO("BMI160 get started...");
        printf("\r\BMI160 started.\r\n");
        Acc_delay_ms(100);
        advertising_start();
        printf("\r\advertising started.\r\n");
        Acc_delay_ms(100);
        twi_init();
        printf("\r\twi_init.\r\n");
        Acc_delay_ms(50);
        BMI160_init();
        printf("\r\BMI160_init.\r\n");
        Acc_delay_ms(100);
        // Enter main loop.
        for (;;)
            read_sensor_data();
            //idle_state_handle();
        //for (;;)
        //    idle_state_handle();
        //    nrf_delay_ms( 1000 ) ;
        //    read_sensor_data();
        //    NRF_LOG_FLUSH();
        //    nrf_delay_ms( 100 ) ;
       //     sample_data[0] = 0x20;
       //     sample_data[1] = 0x21;
       //     nrf_drv_twi_tx(&m_twi, 0x69, sample_data, 2, false);
       //     nrf_drv_twi_rx(&m_twi, 0x69, sample_data, 2);
          //  NRF_LOG_INFO("Temperature:" NRF_LOG_FLOAT_MARKER,
          //  NRF_LOG_FLOAT((((sample_data[1]<<8|sample_data[0])*0.001953125)+23.0)));
          //  NRF_LOG_FLUSH();
         //   nrf_delay_ms( 300 ) ;
        //    float accelX = ((((float)accel.x) / G_TO_LSB) * 9.80655); // in m/s^2
        //    float gyrX = ((((float)gyro.x) / DPS_TO_LSB) * 0.0174532925); // in rad/sec
        //    NRF_LOG_INFO("DataX in m/s^2   : " NRF_LOG_FLOAT_MARKER,
       //     NRF_LOG_FLOAT( accelX));
       //     NRF_LOG_INFO("DataY in rad/sec : " NRF_LOG_FLOAT_MARKER,
       //     NRF_LOG_FLOAT(gyrX));
           // NRF_LOG_FLUSH();
    It seems to me that either I'm not getting data from the accelerometer or I'm not converting it to a string correctly.
    That should be easy to check. Just run the debugger and check if the values in the 'accel' struct is what you expect or not.
  • assign it as
    char str[80;
    uint16_t length1;
    and check it and also check for update in nrfconnect app
    when ever you try to send the data in nrf connect it will show the receiving hex , and it was missing here
