BT5 long range feature and nRF Connect scanning
I am developing a beacon using the long range feature of BT5. In order to do so, I added the line m_adv_params.primary_phy   = BLE_GAP_PHY_CODED in advertising_init(). I see the beacon in the nRF Connect Android App. This raises two questions:
  • Is the 150kbps or the 500kbps mode used ?
  • My smartphone is not BT5-compatible, I was not expecting to see the beacon using it. Does it mean that the configuration of the beacon was not properly done ?
  • Hi.
    Which SDK and SoftDevice have you used?
    In SDK 15.0 with SoftDevice 6.0.0 it always 125 kbps, not 150 kbps or 500 kbps.
     Then the configuration is not correct, you should not be able to see CODED_PHY advertiser on a non BT5 phone.
    - Andreas
