Hi all.
I have a working multi-link central NUS project, and a working USB_CDC project for the nRF52840 SDK 15, nordic dev board.
I have merged the two as I need a USB interface in my multi link project. After many hours of errors I have got the thing built, but I get a Fatal error around this part of the code;
ret = app_usbd_init(&usbd_config);
APP_ERROR_CHECK(ret);
Attached is my main.c.
If I move the following to below the app_usbd_init() then I don't get the error and the bluetooth functionality works, but the USB does not enumerate.
ble_stack_init();
gatt_init();
db_discovery_init();
// lbs_c_init();
nus_c_init();
ble_conn_state_init();
Any help would be appreciated. Maybe some of the USBs resources are being used by the softdevice?
Thanks
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
* @brief BLE LED Button Service central and client application main file.
* This example can be a central for up to 8 peripherals.
* The peripheral is called ble_app_blinky and can be found in the ble_peripheral
* folder.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "ble_nus_c.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "app_usbd_core.h"
#include "app_usbd.h"
#include "app_usbd_string_desc.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_serial_num.h"
#include "nrf_drv_power.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "bsp_cli.h"
#include "nrf_cli.h"
#include "nrf_cli_uart.h"
#include "nrf_queue.h"
#define LED_USB_RESUME (7)
#define LED_CDC_ACM_OPEN (8)
#define LED_CDC_ACM_RX (9)
#define LED_CDC_ACM_TX (10)
#define BTN_CDC_DATA_SEND 0
#define BTN_CDC_NOTIFY_SEND 1
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref APP_BLE_CONN_CFG_TAG. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define CENTRAL_SCANNING_LED BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED BSP_BOARD_LED_1
#define LEDBUTTON_LED BSP_BOARD_LED_2 /**< LED to indicate a change of state of the the Button characteristic on the peer. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define LEDBUTTON_BUTTON BSP_BUTTON_0 /**< Button that will write to the LED characteristic of the peer. */
#define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION 0x0000 /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning will continue until it is explicitly disabled. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(10, UNIT_1_25_MS) /**< Determines maximum connection interval in milliseconds. */
#define SLAVE_LATENCY 0 /**< Determines slave latency in terms of connection events. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 milliseconds. */
uint16_t dataLength = 0;
uint16_t reportLength = 0;
uint8_t txPower = 0;
uint8_t rssi = 0;
uint8_t test2[];
uint32_t count = 0;
uint8_t block = 0;
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
//BLE_LBS_C_ARRAY_DEF(m_lbs_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT); /**< LED Button client instances. */
BLE_NUS_C_ARRAY_DEF(m_nus_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT); /**< Database discovery module instances. */
static char const m_target_periph_name[] = "SWTG1"; /**< Name of the device we try to connect to. This name is searched for in the scan report data*/
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
m_scan_buffer_data,
/**@brief Scan parameters requested for scanning and connection. */
static ble_gap_scan_params_t const m_scan_params =
.active = 0, //was 0
.interval = SCAN_INTERVAL,
.window = SCAN_WINDOW,
.timeout = SCAN_DURATION,
.scan_phys = BLE_GAP_PHY_1MBPS,
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
/**@brief NUS uuid. */
static ble_uuid_t const m_nus_uuid =
.uuid = BLE_UUID_NUS_SERVICE,
.type = NUS_SERVICE_UUID_TYPE
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
(uint16_t)MIN_CONNECTION_INTERVAL,
(uint16_t)MAX_CONNECTION_INTERVAL,
(uint16_t)SLAVE_LATENCY,
(uint16_t)SUPERVISION_TIMEOUT
//USB CDC *************
* @brief Enable power USB detection
* Configure if example supports USB port connection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
void clocks_start( void )
while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
app_usbd_cdc_acm_user_event_t event);
#define CDC_ACM_COMM_INTERFACE 0
#define CDC_ACM_COMM_EPIN NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE 1
#define CDC_ACM_DATA_EPIN NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT NRF_DRV_USBD_EPOUT1
* @brief CDC_ACM class instance
APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
cdc_acm_user_ev_handler,
CDC_ACM_COMM_INTERFACE,
CDC_ACM_DATA_INTERFACE,
CDC_ACM_COMM_EPIN,
CDC_ACM_DATA_EPIN,
CDC_ACM_DATA_EPOUT,
APP_USBD_CDC_COMM_PROTOCOL_AT_V250
#define READ_SIZE 2
//static char m_rx_buffer[READ_SIZE];
static char m_rx_buffer[NRF_DRV_USBD_EPSIZE];
static char m_tx_buffer[1024];//NRF_DRV_USBD_EPSIZE];
static bool m_send_flag = 0;
* @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t (headphones)
size_t size = 0;
app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
switch (event)
case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
bsp_board_led_on(LED_CDC_ACM_OPEN);
/*Setup first transfer*/
size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
m_rx_buffer,
READ_SIZE);
UNUSED_VARIABLE(ret);
case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
bsp_board_led_off(LED_CDC_ACM_OPEN);
case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
bsp_board_led_invert(LED_CDC_ACM_TX);
case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
ret_code_t ret;
NRF_LOG_INFO("Bytes waiting: %d", app_usbd_cdc_acm_bytes_stored(p_cdc_acm));
do
/*Get amount of data transfered*/
NRF_LOG_INFO("RX: size: %lu char: %c", size, m_rx_buffer[0]);
/* Fetch data until internal buffer is empty */
m_rx_buffer,
READ_SIZE);
} while (ret == NRF_SUCCESS);
bsp_board_led_invert(LED_CDC_ACM_RX);
//IM = identify module
if(m_rx_buffer[0] == 'I' & m_rx_buffer[1] == 'M')
size = sprintf(m_tx_buffer, "SWIM03");
//size = 400;
//uint16_t count = 0;
//while(count < 400)
// m_tx_buffer[count] = count;
// count++;
app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, size);
//SB = status bands
else if(m_rx_buffer[0] == 'S' & m_rx_buffer[1] == 'B')
size = 11;
m_tx_buffer[0] = 0;
m_tx_buffer[1] = 99;
m_tx_buffer[2] = 0;
m_tx_buffer[3] = 0;
m_tx_buffer[4] = 0;
m_tx_buffer[5] = 0;
m_tx_buffer[6] = 1;
m_tx_buffer[7] = 3;
m_tx_buffer[8] = 2;
m_tx_buffer[9] = 0;
m_tx_buffer[10] = 30;
//test
else if(m_rx_buffer[0] == 't')
size = 5;
m_tx_buffer[0] = 'H';
m_tx_buffer[1] = 'E';
m_tx_buffer[2] = 'L';
m_tx_buffer[3] = 'L';
m_tx_buffer[4] = 'O';
static void usbd_user_ev_handler(app_usbd_event_type_t event)
switch (event)
case APP_USBD_EVT_DRV_SUSPEND:
bsp_board_led_off(LED_USB_RESUME);
case APP_USBD_EVT_DRV_RESUME:
bsp_board_led_on(LED_USB_RESUME);
case APP_USBD_EVT_STARTED:
case APP_USBD_EVT_STOPPED:
app_usbd_disable();
bsp_board_leds_off();
case APP_USBD_EVT_POWER_DETECTED:
NRF_LOG_INFO("USB power detected");
if (!nrf_drv_usbd_is_enabled())
app_usbd_enable();
case APP_USBD_EVT_POWER_REMOVED:
NRF_LOG_INFO("USB power removed");
app_usbd_stop();
case APP_USBD_EVT_POWER_READY:
NRF_LOG_INFO("USB ready");
app_usbd_start();
//USB CDC************************
/**@brief Function to handle asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for the LEDs initialization.
* @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function to start scanning. */
static void scan_start(void)
ret_code_t ret;
(void) sd_ble_gap_scan_stop();
NRF_LOG_INFO("Start scanning for device name %s.", (uint32_t)m_target_periph_name);
ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
// Turn on the LED to signal scanning.
bsp_board_led_on(CENTRAL_SCANNING_LED);
/**@brief Callback handling NUS Client events.
* @details This function is called to notify the application of NUS client events.
* @param[in] p_ble_nus_c NUS Client Handle. This identifies the NUS client
* @param[in] p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
ret_code_t err_code;
switch (p_ble_nus_evt->evt_type)
case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("NUS service discovered on conn_handle 0x%x", p_ble_nus_evt->conn_handle);
err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
NRF_LOG_INFO("Connected to device with Nordic UART Service.");
count = 0;
case BLE_NUS_C_EVT_NUS_TX_EVT:
//ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
//NRF_LOG_HEXDUMP_INFO(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
count++;
if (count % 32 == 0) {
NRF_LOG_INFO("Receiving data length = %d bytes", p_ble_nus_evt->data_len);
NRF_LOG_INFO("conn_handle 0x%x", p_ble_nus_evt->conn_handle);
NRF_LOG_INFO("Packet # %d", count);
NRF_LOG_INFO("P1 %d : P2 %d", p_ble_nus_evt->p_data[0], p_ble_nus_evt->p_data[1]);
uint8_t size = sprintf(m_tx_buffer, "data");
//NRF_LOG_INFO("Data received : %X", p_ble_nus_evt->p_data);
// case BLE_NUS_C_EVT_DISCONNECTED:
// NRF_LOG_INFO("Disconnected.");
// scan_start();
// break;
/**@brief Function for handling the advertising report BLE event.
* @param[in] p_adv_report Advertising report from the SoftDevice.
static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
//NRF_LOG_INFO("report rx'd");
dataLength = p_adv_report->data.len;
reportLength = sizeof(*p_adv_report);
txPower = p_adv_report->tx_power;
rssi = p_adv_report->rssi;
//memcpy(test2, p_adv_report, sizeof(*p_adv_report));
memcpy(test2, p_adv_report->data.p_data, p_adv_report->data.len);
if (ble_advdata_name_find(p_adv_report->data.p_data,
p_adv_report->data.len,
m_target_periph_name))
//Test code
NRF_LOG_INFO("Name is a match");
// Name is a match, initiate connection.
err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
&m_scan_params,
&m_connection_param,
APP_BLE_CONN_CFG_TAG);
if (err_code != NRF_SUCCESS)
NRF_LOG_ERROR("Connection Request Failed, reason %d", err_code);
//NRF_LOG_INFO("Advertisment wasn't match to %s ", p_adv_report->data.p_data);// m_target_periph_name);
err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
// For readability.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
// Upon connection, check which peripheral has connected, initiate DB
// discovery, update LEDs status and resume scanning if necessary.
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connection 0x%x established, starting DB discovery.",
p_gap_evt->conn_handle);
NRF_LOG_INFO("interval %d", p_gap_evt->params.connected.conn_params.min_conn_interval);
APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < NRF_SDH_BLE_CENTRAL_LINK_COUNT);
//err_code = ble_lbs_c_handles_assign(&m_lbs_c[p_gap_evt->conn_handle],
// p_gap_evt->conn_handle,
// NULL);
err_code = ble_nus_c_handles_assign(&m_nus_c[p_gap_evt->conn_handle],
NULL);
err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle],
if (err_code != NRF_ERROR_BUSY)
// Update LEDs status, and check if we should be looking for more
// peripherals to connect to.
bsp_board_led_on(CENTRAL_CONNECTED_LED);
if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
bsp_board_led_off(CENTRAL_SCANNING_LED);
// Resume scanning.
scan_start();
} break; // BLE_GAP_EVT_CONNECTED
// Upon disconnection, reset the connection handle of the peer which disconnected, update
// the LEDs status and start scanning again.
NRF_LOG_INFO("NUS central link 0x%x disconnected (reason: 0x%x)",
p_gap_evt->params.disconnected.reason);
if (ble_conn_state_central_conn_count() == 0)
err_code = app_button_disable();
// Turn off connection indication LED
bsp_board_led_off(CENTRAL_CONNECTED_LED);
// Start scanning
scan_start();
// Turn on LED for indicating scanning
} break;
case BLE_GAP_EVT_ADV_REPORT:
on_adv_report(&p_gap_evt->params.adv_report);
case BLE_GAP_EVT_TIMEOUT:
// We have not specified a timeout for scanning, so only connection attemps can timeout.
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_DEBUG("Connection request timed out.");
} break;
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
NRF_LOG_DEBUG("BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST.");
// Accept parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
} break;
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
} break;
case BLE_GATTS_EVT_TIMEOUT:
} break;
// No implementation needed.
/**@brief Function for initializing the NUS Client. */
static void nus_c_init(void)
ble_nus_c_init_t nus_c_init_obj;
nus_c_init_obj.evt_handler = ble_nus_c_evt_handler;
for (uint32_t i = 0; i < NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
err_code = ble_nus_c_init(&m_nus_c[i], &nus_c_init_obj);
* @details Initializes the SoftDevice and the BLE event interrupts.
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the button handler module.
* @param[in] pin_no The pin that the event applies to.
* @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
switch (pin_no)
case LEDBUTTON_BUTTON:
//err_code = led_status_send_to_all(button_action);
//if (err_code == NRF_SUCCESS)
// NRF_LOG_INFO("LBS write LED state %d", button_action);
APP_ERROR_HANDLER(pin_no);
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
// The array must be static because a pointer to it will be saved in the button handler module.
static app_button_cfg_t buttons[] =
{LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DETECTION_DELAY);
/**@brief Function for handling database discovery events.
* @details This function is callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function should forward the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
NRF_LOG_DEBUG("call to ble_nus_on_db_disc_evt for instance %d and link 0x%x!",
p_evt->conn_handle,
ble_nus_c_on_db_disc_evt(&m_nus_c[p_evt->conn_handle], p_evt);
/** @brief Database discovery initialization.
static void db_discovery_init(void)
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
* @details Handle any pending log operation(s), then sleep until the next event occurs.
nrf_pwr_mgmt_run();
/** @brief Function for initializing the log module.
static void log_init(void)
/** @brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
NRF_LOG_INFO("ATT MTU exchange completed.");
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
// ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
//USB CDC
ret_code_t ret;
static const app_usbd_config_t usbd_config = {
.ev_state_proc = usbd_user_ev_handler
ret = NRF_LOG_INIT(NULL);
ret = nrf_drv_clock_init();
while(!nrf_drv_clock_lfclk_is_running())
/* Just waiting */
ret = app_timer_init();
clocks_start();
// Initialize.
log_init();
timer_init();
leds_init();
buttons_init();
power_management_init();
ble_stack_init();
gatt_init();
// lbs_c_init();
nus_c_init();
// init_cli();
app_usbd_serial_num_generate();
NRF_LOG_INFO("USBD CDC ACM example started.");
app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
ret = app_usbd_class_append(class_cdc_acm);
if (USBD_POWER_DETECTION)
ret = app_usbd_power_events_enable();
NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
app_usbd_enable();
app_usbd_start();
//fix for multiple connections
for (uint16_t i=0;i<NRF_SDH_BLE_CENTRAL_LINK_COUNT;i++)
m_db_disc[i].conn_handle=BLE_CONN_HANDLE_INVALID;
// Start execution.
NRF_LOG_INFO("Multilink example started.");
scan_start();
for (;;)
while (app_usbd_event_queue_process())
/* Nothing to do */
idle_state_handle();
