Loop in flash_manager_wait function() Mesh SDK 2.2.0, Light Switch Proxy Server Example
Hello, i am having problems with a loop in the function "flash_manager_wait()"; in the begining of the code.
main()-> initialize()-> mesh_init()-> mesh_stack_init(&init_params, &m_device_provisioned))-> dsm_flash_config_load()-> (void) dsm_flash_config_load()-> flash_manager_wait();
static inline void flash_manager_wait(void)
#if !defined(HOST)
//__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "HOLA 1..1..0..1\n");
while (!flash_manager_is_stable())
/* Temporary hack to make sure that bearer events are handled while waiting for
* the flash manager to finish.
* TODO: Find a solution for this that does not include busy-waiting. */
if (bearer_event_handler())
__WFE();
this happen after many reboots thath i do each 1 minute, and the only form to recover it, is erase all the flash, and re flashing soft-device and program.
i do the reboot whit the timer1 and the " function mesh_stack_device_reset()"
 void TIMER1_IRQHandler(void)
        if (NRF_TIMER1->EVENTS_COMPARE[0] == 1 )
              __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Count1 -----\n");
              NRF_TIMER1->EVENTS_COMPARE[0] =  0;
              if ( TIMER_REINICIO1 == 1)
                 nrf_delay_ms(100);
                  mesh_stack_device_reset();
        if (NRF_TIMER1->EVENTS_COMPARE[1] == 1)
               __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Count2 -----\n");
               NRF_TIMER1->EVENTS_COMPARE[1] = 0;
               if ( TIMER_REINICIO2 == 1)
                 nrf_delay_ms(100);
help please.
    I have been talking to our Mesh Group, and this was an issue that they were aware of, and that they have actually fixed. Unfortunately, it is not a simple one liner, and the fix is spread out on several files.
    I have tested the current dev branch of the Mesh SDK, and your application (main.c file) works as intended in that version. Unfortunately, I can't distribute this version now, but it will be included in the next release.
    The issue is related to that the flash manager is waiting for a flash operation to be preformed, before the module that is going to perform this operation is initialized.
    The issue should occur after about 500 resets with the currently available SDK for Mesh (2.2.0). Is this something you can work with until the official release is available? I can't give any guarantees for when that will happen, but it shouldn't be too long. Is this bug making it impossible for you to continue the development?
    Edvin
  • Hi Edvin
    I'm having the same issue as reported by davidesteban13 above, ie hangs @ flash_manager_wait() using mesh stack 2.2.0, an nRF52840-DK,  S140_6.1.0 and an En_Ocean PTM215B switch.
    I have a production deadline to meet. Does Nordic have any other mitigation strategy other than asking customers to wait for the next as yet un-anounced SDK release?
    Millicent
    The fix is implemented in the 3.0.0 release of the SDK. The flash manager has had a makeover. You can either port your application to this SDK version, or you can try to backport the flash manager. I recommend the first one.
    Edvin
