I have a secure bootloader and an application on nRF52840 with SD 15.2.
I try to add watchdog support in application based on watchdog exemple but if i remove feed, it not resets…
Do someone have an idea please ?
Thank you.
Thank you.
Fabien Comte I have used the Watchdog in more than one application and I can assure you it definately resets the chip. Can you share some of the WD init code?
Thanks
Sorry my title have several senses. I am sure that it works but not in my case :-)
nrf_drv_wdt_channel_id m_channel_id;
void wdt_event_handler(void)
//BSP configuration for button support: button pushing will feed the dog.
uint32_t err_code = nrf_drv_clock_init();
//Configure WDT.
nrf_drv_wdt_config_t config = NRF_DRV_WDT_DEAFULT_CONFIG;
uint32_t err_code = nrf_drv_wdt_init(&config, wdt_event_handler);
err_code = nrf_drv_wdt_channel_alloc(&m_channel_id);
nrf_drv_wdt_enable();
nrf_drv_wdt_channel_feed(m_channel_id);
ble_stack_init();
while (1)
//nrf_drv_wdt_channel_feed(m_channel_id); // commented to expect reset
Some quick questions:
Kenneth
I agree with Kenneth, more information is required to help and his list is a great place to start. Some other details I thought of:
Hello Kenneth and Darren,
Kenneth answers
- SDK's example looks without SD and probably no bootloaded too.
- A LED that blink on startup.
- Yes for reload. I wanted 15 s so i tried 15000 and 15 x 32768 without success.
- Hard to say, it's in a fanstel module. Can I read any register to know ?
Thank you for your help.
Darren answers
- For RTT but I also tried without.
- I do a test with a basic loop with GPIO toggle without any success too.
Thank you both for your helps
