Invalid EID in Eddystone example
The code assumes that check_rollovers_and_update_eid(...) is called every second, and that m_security_slot[slot_no].timing increases monotonically with 1. If this is not the case, one might miss out on the check where EID is updated, and you will have a stale EID until next wrap-around.
  • The issue is fixed by replacing the file in nRF5_SDK_15.2.0_9412b96\components\ble\ble_services\eddystone with the attached file:
     * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdbool.h>
    #include <stdint.h>
    #include "es_security.h"
    #include "app_timer.h"
    #include "es_flash.h"
    #include "es_stopwatch.h"
    #include "fds.h"
    #include "modes.h"
    #include "nrf_crypto.h"
    #include "nrf_soc.h"
    #define NONCE_SIZE                  (6)
    #define TAG_SIZE                    (2)
    #define SALT_SIZE                   (2)
    #define TLM_DATA_SIZE               (ES_TLM_LENGTH - 2)
    #define EIK_SIZE                    (ESCS_AES_KEY_SIZE)
    #define AES_ECB_CIPHERTEXT_LENGTH   (16)
    #define AES_ECB_CLEARTEXT_LENGTH    (16)
    /**@brief Timing structure. */
    typedef struct
        uint32_t time_counter;
        uint8_t  k_scaler;
    } es_security_timing_t;
    /**@brief Security slot structure. */
    typedef struct
        nrf_ecb_hal_data_t   aes_ecb_ik;
        nrf_ecb_hal_data_t   aes_ecb_tk;
        uint8_t              eid[ES_EID_ID_LENGTH];
        es_security_timing_t timing;
        bool                 is_occupied;
    } es_security_slot_t;
    /**@brief Key pair structure. */
    typedef struct
        nrf_crypto_ecc_private_key_t private;
        nrf_crypto_ecc_public_key_t  public;
    } ecdh_key_pair_t;
    /**@brief ECDH structure. */
    typedef struct
        ecdh_key_pair_t ecdh_key_pair;
    } es_security_ecdh_t;
    static nrf_ecb_hal_data_t                           m_aes_ecb_lk;
    static es_security_slot_t                           m_security_slot[APP_MAX_EID_SLOTS];
    static es_security_ecdh_t                           m_ecdh;
    static es_security_msg_cb_t                         m_security_callback;
    static es_stopwatch_id_t                            m_seconds_passed_sw_id;
    // Use static context variables to avoid stack allocation.
    static nrf_crypto_aes_context_t                     m_aes_context;
    static nrf_crypto_hmac_context_t                    m_hmac_context;
    static nrf_crypto_aead_context_t                    m_aead_context;
    static nrf_crypto_ecc_key_pair_generate_context_t   ecc_key_pair_generate_context;
    static nrf_crypto_ecdh_context_t                    ecdh_context;
    /**@brief Generates a temporary key with the Identity key. */
    static void temp_key_generate(uint8_t slot_no);
    /**@brief Generates a EID with the Temporary Key*/
    static void eid_generate(uint8_t slot_no)
        ret_code_t  err_code;
        size_t      ciphertext_size = AES_ECB_CIPHERTEXT_LENGTH;
        temp_key_generate(slot_no);
        memset(m_security_slot[slot_no].aes_ecb_tk.cleartext, 0, ESCS_AES_KEY_SIZE);
        m_security_slot[slot_no].aes_ecb_tk.cleartext[11] = m_security_slot[slot_no].timing.k_scaler;
        uint32_t k_bits_cleared_time =
            (m_security_slot[slot_no].timing.time_counter >> m_security_slot[slot_no].timing.k_scaler)
            << m_security_slot[slot_no].timing.k_scaler;
        m_security_slot[slot_no].aes_ecb_tk.cleartext[12] =
            (uint8_t)((k_bits_cleared_time >> 24) & 0xff);
        m_security_slot[slot_no].aes_ecb_tk.cleartext[13] =
            (uint8_t)((k_bits_cleared_time >> 16) & 0xff);
        m_security_slot[slot_no].aes_ecb_tk.cleartext[14] = (uint8_t)((k_bits_cleared_time >> 8) & 0xff);
        m_security_slot[slot_no].aes_ecb_tk.cleartext[15] = (uint8_t)((k_bits_cleared_time) & 0xff);
        err_code = nrf_crypto_aes_crypt(&m_aes_context,
                                        &g_nrf_crypto_aes_ecb_128_info,
                                        NRF_CRYPTO_ENCRYPT,                             // Operation
                                        m_security_slot[slot_no].aes_ecb_tk.key,        // Key
                                        NULL,                                           // IV
                                        m_security_slot[slot_no].aes_ecb_tk.cleartext,  // Data in
                                        AES_ECB_CLEARTEXT_LENGTH,                       // Data in size
                                        m_security_slot[slot_no].aes_ecb_tk.ciphertext, // Data out
                                        &ciphertext_size);                              // Data out size
        memcpy(m_security_slot[slot_no].eid,
               ES_EID_ID_LENGTH);
        m_security_callback(slot_no, ES_SECURITY_MSG_EID);
        memset(m_security_slot[slot_no].aes_ecb_ik.cleartext, 0, ESCS_AES_KEY_SIZE);
        m_security_slot[slot_no].aes_ecb_ik.cleartext[11] = 0xFF;
        m_security_slot[slot_no].aes_ecb_ik.cleartext[14] =
            (uint8_t)((m_security_slot[slot_no].timing.time_counter >> 24) & 0xff);
        m_security_slot[slot_no].aes_ecb_ik.cleartext[15] =
            (uint8_t)((m_security_slot[slot_no].timing.time_counter >> 16) & 0xff);
                                        m_security_slot[slot_no].aes_ecb_ik.key,        // Key
                                        NULL,                                           // IV
                                        m_security_slot[slot_no].aes_ecb_ik.cleartext,  // Data in
                                        m_security_slot[slot_no].aes_ecb_ik.ciphertext, // Data out
        memcpy(m_security_slot[slot_no].aes_ecb_tk.key,
               ESCS_AES_KEY_SIZE);
    /**@brief See if EID should be re-calculated.
    static void check_rollovers_and_update_eid(uint8_t slot_no)
        static uint32_t last_invocation_time_counter = 0;
        uint32_t scaler = 2 << (m_security_slot[slot_no].timing.k_scaler - 1);
        uint32_t diff;
        if (last_invocation_time_counter == 0)
            last_invocation_time_counter = m_security_slot[slot_no].timing.time_counter;
        diff = m_security_slot[slot_no].timing.time_counter - last_invocation_time_counter;
        if (diff >= scaler)
            // Store to last scaler-aligned time.
            last_invocation_time_counter = (m_security_slot[slot_no].timing.time_counter / scaler) * scaler;
            eid_generate(slot_no);
    /**@brief Initialize lock code from flash. If it does not exist, copy from APP_CONFIG_LOCK_CODE.
    static void lock_code_init(uint8_t * p_lock_buff)
        err_code = es_flash_access_lock_key(p_lock_buff, ES_FLASH_ACCESS_READ);
        FLASH_ACCES_ERROR_CHECK_ALLOW_NOT_FOUND(err_code);
        // If no lock keys exist, then generate one and copy it to buffer.
        if (err_code == FDS_ERR_NOT_FOUND)
            uint8_t lock_code[16] = APP_CONFIG_LOCK_CODE;
            memcpy(p_lock_buff, lock_code, sizeof(lock_code));
            err_code = es_flash_access_lock_key(p_lock_buff, ES_FLASH_ACCESS_WRITE);
    void es_security_update_time(void)
        static uint32_t timer_persist;
        uint32_t        second_since_last_invocation = es_stopwatch_check(m_seconds_passed_sw_id);
        if (second_since_last_invocation > 0)
            for (uint32_t i = 0; i < APP_MAX_EID_SLOTS; ++i)
                if (m_security_slot[i].is_occupied)
                    m_security_slot[i].timing.time_counter += second_since_last_invocation;
                    check_rollovers_and_update_eid(i);
            // Every 24 hr, write the new EID timer to flash.
            timer_persist += second_since_last_invocation;
            const uint32_t TWENTY_FOUR_HOURS = 60 * 60 * 24;
            if (timer_persist >= TWENTY_FOUR_HOURS)
                        m_security_callback(i, ES_SECURITY_MSG_STORE_TIME);
                timer_persist = 0;
    void es_security_eid_slots_restore(uint8_t         slot_no,
                                       uint8_t         k_scaler,
                                       uint32_t        time_counter,
                                       const uint8_t * p_ik)
        m_security_slot[slot_no].timing.k_scaler     = k_scaler;
        m_security_slot[slot_no].timing.time_counter = time_counter;
        memcpy(m_security_slot[slot_no].aes_ecb_ik.key, p_ik, ESCS_AES_KEY_SIZE);
        m_security_slot[slot_no].is_occupied = true;
        m_security_callback(slot_no, ES_SECURITY_MSG_IK);
    ret_code_t es_security_lock_code_update(uint8_t * p_ecrypted_key)
        uint8_t     temp_buff[ESCS_AES_KEY_SIZE] = {0};
        size_t      temp_buff_size = sizeof(temp_buff);
                                        NRF_CRYPTO_DECRYPT,             // Operation
                                        m_aes_ecb_lk.key,               // Key
                                        NULL,                           // IV
                                        p_ecrypted_key,                 // Data in
                                        16,                             // Data in size
                                        temp_buff,                      // Data out
                                        &temp_buff_size);               // Data out size
        VERIFY_SUCCESS(err_code);
        memcpy(m_aes_ecb_lk.key, temp_buff, ESCS_AES_KEY_SIZE);
        return es_flash_access_lock_key(m_aes_ecb_lk.key, ES_FLASH_ACCESS_WRITE);
    void es_security_unlock_prepare(uint8_t * p_challenge)
        memcpy(m_aes_ecb_lk.cleartext, p_challenge, ESCS_AES_KEY_SIZE);
                                        NULL,                           // IV
                                        m_aes_ecb_lk.cleartext,         // Data in
                                        m_aes_ecb_lk.ciphertext,        // Data out
    void es_security_unlock_verify(uint8_t * p_unlock_token)
        if (memcmp(p_unlock_token, m_aes_ecb_lk.ciphertext, ESCS_AES_KEY_SIZE) == 0)
            m_security_callback(0, ES_SECURITY_MSG_UNLOCKED);
    ret_code_t es_security_random_challenge_generate(uint8_t * p_rand_chlg_buff)
        return nrf_crypto_rng_vector_generate(p_rand_chlg_buff, ESCS_AES_KEY_SIZE);
    void es_security_shared_ik_receive(uint8_t slot_no, uint8_t * p_encrypted_ik, uint8_t scaler_k)
        size_t      cleartext_size = AES_ECB_CLEARTEXT_LENGTH;
        m_security_slot[slot_no].timing.k_scaler     = scaler_k;
        m_security_slot[slot_no].timing.time_counter = APP_CONFIG_TIMING_INIT_VALUE;
                                        NULL,                                       // IV
                                        p_encrypted_ik,                             // Data in
                                        16,                                         // Data in size
                                        m_security_slot[slot_no].aes_ecb_ik.key,    // Data out
                                        &cleartext_size);                           // Data out size
    void es_security_client_pub_ecdh_receive(uint8_t slot_no, uint8_t * p_pub_ecdh, uint8_t scaler_k)
        nrf_crypto_ecc_public_key_t phone_public;                       // Phone public ECDH key
        uint8_t                     beacon_public[ESCS_ECDH_KEY_SIZE];  // Beacon public ECDH key
        uint8_t                     shared[ESCS_ECDH_KEY_SIZE];         // Shared secret ECDH key
        uint8_t                     public_keys[64];                    // Buffer for concatenated public keys
        uint8_t                     key_material[64];                   // Buffer for holding key material
        uint8_t                     empty_check[ESCS_ECDH_KEY_SIZE]     = {0};
        size_t                      beacon_public_size                  = sizeof(beacon_public);
        size_t                      shared_size                         = sizeof(shared);
        size_t                      key_material_size                   = sizeof(key_material);
        // Get public 32-byte service ECDH key from phone.
        err_code = nrf_crypto_ecc_public_key_from_raw(&g_nrf_crypto_ecc_curve25519_curve_info,
                                                      &phone_public,
                                                      p_pub_ecdh,
                                                      ESCS_ECDH_KEY_SIZE);
        // Generate key pair.
        err_code = nrf_crypto_ecc_key_pair_generate(&ecc_key_pair_generate_context,
                                                    &m_ecdh.ecdh_key_pair.private,
                                                    &m_ecdh.ecdh_key_pair.public);
        // Generate shared 32-byte ECDH secret from beacon private service ECDH key and phone public ECDH key.
        err_code = nrf_crypto_ecdh_compute(&ecdh_context,
                                           &phone_public,
                                           shared,
                                           &shared_size);
        // Verify that the shared secret is not zero at this point, and report an error/reset if it is.
        if (memcmp(empty_check, shared, ESCS_ECDH_KEY_SIZE) == 0)
            APP_ERROR_CHECK(NRF_ERROR_INTERNAL);
        // Concatenate the resolver's public key and beacon's public key
        err_code = nrf_crypto_ecc_public_key_to_raw(&m_ecdh.ecdh_key_pair.public,
                                                    beacon_public,
                                                    &beacon_public_size);
        memcpy(public_keys, p_pub_ecdh, 32);
        memcpy(public_keys + 32, beacon_public, 32);
        // Convert the shared secret to key material using HKDF-SHA256. HKDF is used with the salt set
        // to a concatenation of the resolver's public key and beacon's public key
        err_code = nrf_crypto_hkdf_calculate(&m_hmac_context,
                                             &g_nrf_crypto_hmac_sha256_info,
                                             key_material,                          // Output key
                                             &key_material_size,                    // Output key size
                                             shared,                                // Input key
                                             sizeof(shared),                        // Input key size
                                             public_keys,                           // Salt
                                             sizeof(public_keys),                   // Salt size
                                             NULL,                                  // Additional info
                                             0,                                     // Additional info size
                                             NRF_CRYPTO_HKDF_EXTRACT_AND_EXPAND);   // Mode
        // Truncate the key material to 128 bits to convert it to an AES-128 secret key (Identity key).
        memcpy(m_security_slot[slot_no].aes_ecb_ik.key, key_material, ESCS_AES_KEY_SIZE);
        m_security_callback(slot_no, ES_SECURITY_MSG_ECDH);
    void es_security_pub_ecdh_get(uint8_t slot_no, uint8_t * p_edch_buffer)
        size_t      buffer_size = ESCS_ECDH_KEY_SIZE;
                                                    p_edch_buffer,
                                                    &buffer_size);
    uint32_t es_security_clock_get(uint8_t slot_no)
        return m_security_slot[slot_no].timing.time_counter;
    void es_security_eid_slot_destroy(uint8_t slot_no)
        memset(&m_security_slot[slot_no], 0, sizeof(es_security_slot_t));
    uint8_t es_security_scaler_get(uint8_t slot_no)
        return m_security_slot[slot_no].timing.k_scaler;
    void es_security_eid_get(uint8_t slot_no, uint8_t * p_eid_buffer)
        memcpy(p_eid_buffer, m_security_slot[slot_no].eid, ES_EID_ID_LENGTH);
    void es_security_encrypted_eid_id_key_get(uint8_t slot_no, uint8_t * p_key_buffer)
        memcpy(m_aes_ecb_lk.cleartext, m_security_slot[slot_no].aes_ecb_ik.key, ESCS_AES_KEY_SIZE);
                                        NULL,                           // IV
        memcpy(p_key_buffer, m_aes_ecb_lk.ciphertext, ESCS_AES_KEY_SIZE);
    void es_security_plain_eid_id_key_get(uint8_t slot_no, uint8_t * p_key_buffer)
        memcpy(p_key_buffer, m_security_slot[slot_no].aes_ecb_ik.key, ESCS_AES_KEY_SIZE);
    void es_security_tlm_to_etlm(uint8_t ik_slot_no, es_tlm_frame_t * p_tlm, es_etlm_frame_t * p_etlm)
        uint8_t     plain[TLM_DATA_SIZE] = {0};             // Plaintext tlm, without the frame byte and version.
        size_t      nplain               = TLM_DATA_SIZE;   // Length of message plaintext.
        /*lint -save -e420 */
        memcpy(plain, &p_tlm->vbatt[0], sizeof(plain));
        uint8_t key[EIK_SIZE] = {0};      // Encryption/decryption key: EIK.
        memcpy(key, &m_security_slot[ik_slot_no].aes_ecb_ik.key[0], EIK_SIZE);
        /*lint -restore */
        uint8_t nonce[NONCE_SIZE] = {0};        // Nonce. This must not repeat for a given key.
        size_t  nnonce            = NONCE_SIZE; // Length of nonce.First 4 bytes are beacon time base with k-bits cleared.
                                                // Last two bits are randomly generated
        // Take the current timestamp and clear the lowest K bits, use it as nonce.
        uint32_t k_bits_cleared_time = (m_security_slot[ik_slot_no].timing.time_counter
                                        >> m_security_slot[ik_slot_no].timing.k_scaler)
                                       << m_security_slot[ik_slot_no].timing.k_scaler;
        nonce[0] = (uint8_t)((k_bits_cleared_time >> 24) & 0xff);
        nonce[1] = (uint8_t)((k_bits_cleared_time >> 16) & 0xff);
        nonce[2] = (uint8_t)((k_bits_cleared_time >> 8) & 0xff);
        nonce[3] = (uint8_t)((k_bits_cleared_time) & 0xff);
        // Generate random salt.
        uint8_t salt[SALT_SIZE] = {0};
        err_code = nrf_crypto_rng_vector_generate(salt, SALT_SIZE);
        memcpy(&nonce[4], salt, SALT_SIZE);
        uint8_t cipher[ES_ETLM_ECRYPTED_LENGTH]; // Ciphertext output. nplain bytes are written.
        uint8_t tag[TAG_SIZE] = {0};             // Authentication tag. ntag bytes are written.
        size_t  ntag          = TAG_SIZE;        // Length of authentication tag.
        // Encryption
        err_code = nrf_crypto_aead_init(&m_aead_context, &g_nrf_crypto_aes_eax_128_info, key);
        err_code = nrf_crypto_aead_crypt(&m_aead_context,
                                         nonce,              // Nonce
                                         nnonce,             // Nonce size
                                         NULL,               // Additional authenticated data (adata)
                                         0,                  // Additional authenticated data size
                                         plain,              // Input data
                                         nplain,             // Input data size
                                         cipher,             // Output data
                                         tag,                // MAC result output
                                         ntag);              // MAC size
        err_code = nrf_crypto_aead_uninit(&m_aead_context);
        // Construct the eTLM.
        p_etlm->frame_type = p_tlm->frame_type;
        p_etlm->version    = ES_TLM_VERSION_ETLM;
        memcpy(p_etlm->encrypted_tlm, cipher, ES_ETLM_ECRYPTED_LENGTH);
        memcpy((uint8_t *)&p_etlm->random_salt, salt, SALT_SIZE);
        memcpy((uint8_t *)&p_etlm->msg_integrity_check, tag, TAG_SIZE);
    ret_code_t es_security_init(es_security_msg_cb_t security_callback)
        if (security_callback == NULL)
            return NRF_ERROR_INVALID_PARAM;
        // Get lock code from 'es_app_config.h', or fetch it from flash if exists.
        lock_code_init(m_aes_ecb_lk.key);
        m_security_callback = security_callback;
        memset(&m_ecdh, 0, sizeof(es_security_ecdh_t));
            m_security_slot[i].timing.time_counter = APP_CONFIG_TIMING_INIT_VALUE;
        err_code = es_stopwatch_create(&m_seconds_passed_sw_id, APP_TIMER_TICKS(1000));
        err_code = nrf_crypto_init();
        return NRF_SUCCESS;
