Regarding Python Scripts for nrf52840 to connect and transfer data.
Hi ,
What I am trying:-
-connect the custom board with nrf52840 chip using nrf52 dongle on pc with python.
-Already set some commands on custom board so when my pc (via dongle) connects to custom board, I want to send some commands and accordingly receive the response.
For this I got my hands-on nrf dongle to give my laptop a BLE access.
And I am trying to access the board using dongle (using python script) and I am getting below error,
raise NordicSemiException('Failed to {}. Error code: {}'.format(wrapped.__name__, err_code))
pc_ble_driver_py.exceptions.NordicSemiException: Failed to open. Error code: 13.
Would anyone able to tell me how do i resolve this.
I want to have python code that can connect and do some data transfer over BLE using Dongle connected to my pc and I have tried with hart_rate_monitor unsuccessfully.
EDIT 1:- I am able to scan and connect my board using the nRF Connect windows app. Same I wanted to implement over python.
Hinesh
    Can you provide the full command that you run (for starting the python script) and all output to the command line afterwards? (Both what parameters you send to the script, any debug output, and the full traceback may give clues as to what is the problem.)
    Terje
  • HI
    Actually I have resolved the above error.
    By going through various questions and answers here I came to know some tools.
    So When I was opening 'nrf connect' windows app , it was flashing firmware and I was having impression that this will be samefirmware will be used for scanning and connect via python. But It was not working.
    And the I have installed windows command line tools and format the board using 'nrfproject' command. And Let the python  application 'Hear rate monitor' do the flashing. Then it started working.
    It seems the mismatch on the firmware version on nrf52840 PDK Board (that I am using as dongle to connect to custom board via my pc).
    So To come on another query I have,
    Can you point me any example or script that can do the same work as 'nrf connect' does?
    Scan, connect (to particular given mac id) and explore services of connected device.
    Basically I am trying what I have explained on above question.
    This would be very help full for us as we are already on advance stage for development.
    Hinesh
    You will see in the heart rate collector example of pc-ble-driver-py, that there is a condition on the device name (variable "dev_name") in the on_gap_evt_adv_report() funciton. So in that example, connections are filtered based on device name. You can replace that if block with any other check, including a check on the "peer_addr" which is the address of the advertising device. In the same example, service discovery is done in connect_and_discover().
    Terje
  • So Basically in my understanding, Please check comments on below code.
    And peer address here is the mac id of the advertising device or the name ?
        def on_gap_evt_adv_report(self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data): #peer address is my adverstiseing device that needs to be connected
            dev_name_list = None #Here change with dongle name
            if BLEAdvData.Types.complete_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
            elif BLEAdvData.Types.short_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
    I will do a trial now and let you know about result.
    EDIT:- I have edited the parameters but upon running, It's asking for
    'Please specify connectivity IC identifier (NRF51, NRF52)'
    I have also hard coded the device in config.py file on __conn_ic_id__ = "NRF52".
    But still while running the code it's asking for the IC identifier.
    Here I am trying to connect to device (example) with mac :- 11:22:33:44:55:66.
    This device I am able to see in the scan list as address and I can see the device name as well.
    Any comments on this?
    Hinesh
    You will need something along the lines of:
    if (peer_addr == TARGET_PEER_ADDR)
        self.adapter.connect(peer_addr)
    Instead of the current if that checks the dev_name. And also, you must define the TARGET_PEER_ADDR constant to be the address of the device, similar to how in the example they define a constant TARGET_DEV_NAME for the name of the device.
    For the error that you see, you will see at at the very end of the heart_rate_collector.py the code that leads to that error being displayed. It is code handling the arguments that you provide when running the example. If you want to use a hard coded connection IC ID then you can change that test, and also change the line "init(sys.argv[1])" to use the hard coded connection IC ID instead of sys.argv[1] as its argument.
    Please note that the argv array contains all the arguments that you provide on the command line, and so if you do not use the first argument any more then you must do additional changes in order for the other arguments to work as intended. I will leave it up to you to decide what arguments you want and for what purposes.
    I cannot do the work for you, but hopefully this should be enough for you to get going.
    Terje
