Bootloader causes NRF52840 to stop advertising
I am trying to program the bootloader for the nrf52840. I am trying to create a settings for the specific hex file, and then programming using the nrfjprog commands. But for some reason, whenever i upload the bootloader on top of the soft device and the program, the device stops advertising.
Here are the commands i am using:
nrfutil settings generate --family NRF52840 --application ..\Firmware\version\s140\armgcc\_build\nrf52840_xxaa.hex --application-version 2 --bootloader-version 2 --bl-settings-version 1 settingsV10.hex --no-backup
mergehex -m secure_bootloader\pca10056_ble\armgcc\_build\nrf52840_xxaa_s140.hex settingsV10.hex -o bootloaderV10.hex
nrfjprog --family NRF52 -e
nrfjprog --reset --program ..\..\components\softdevice\s140\hex\s140_nrf52_6.0.0_softdevice.hex --family NRF52 --sectoranduicrerase
nrfjprog --reset --program ..\Firmware\version\s140\armgcc\_build\nrf52840_xxaa.hex --family NRF52 --sectoranduicrerase
nrfjprog --reset --program bootloaderV10.hex --family NRF52 --sectoranduicrerase
    The bootloader hex file will write to the UICR, so you should not run --sectoranduicrerase in any of the three program commands after you run eraseall.
    Marjeris
  • I've tried that. It does not work. As far as i know, there seems to be an image problem with the application hex file.
  • Can you send me the linker script for you application? I want to make sure that you're allocating enough memory for the BL. If the bootloader advertises when you only flash the BL+SD, then its highly likely that the issue is in the application. So could you try to debug the application after you have flashed the SD+BL+Settings+ APP?
  • /* Linker script to configure memory regions. */
    SEARCH_DIR(.)
    GROUP(-lgcc -lc -lnosys)
    MEMORY
      FLASH (rx) : ORIGIN = 0xf8000, LENGTH = 0x6000
      RAM (rwx) :  ORIGIN = 0x200057b8, LENGTH = 0x3a848
      uicr_mbr_params_page (r) : ORIGIN = 0x10001018, LENGTH = 0x4
      mbr_params_page (r) : ORIGIN = 0x000FE000, LENGTH = 0x1000
      bootloader_settings_page (r) : ORIGIN = 0x000FF000, LENGTH = 0x1000
      uicr_bootloader_start_address (r) : ORIGIN = 0x10001014, LENGTH = 0x4
    SECTIONS
      .uicr_mbr_params_page :
        PROVIDE(__start_uicr_mbr_params_page = .);
        KEEP(*(SORT(.uicr_mbr_params_page*)))
        PROVIDE(__stop_uicr_mbr_params_page = .);
      } > uicr_mbr_params_page
      .mbr_params_page(NOLOAD) :
        PROVIDE(__start_mbr_params_page = .);
        KEEP(*(SORT(.mbr_params_page*)))
        PROVIDE(__stop_mbr_params_page = .);
      } > mbr_params_page
      .bootloader_settings_page(NOLOAD) :
        PROVIDE(__start_bootloader_settings_page = .);
        KEEP(*(SORT(.bootloader_settings_page*)))
        PROVIDE(__stop_bootloader_settings_page = .);
      } > bootloader_settings_page
      .uicr_bootloader_start_address :
        PROVIDE(__start_uicr_bootloader_start_address = .);
        KEEP(*(SORT(.uicr_bootloader_start_address*)))
        PROVIDE(__stop_uicr_bootloader_start_address = .);
      } > uicr_bootloader_start_address
    SECTIONS
      . = ALIGN(4);
      .mem_section_dummy_ram :
      .log_dynamic_data :
        PROVIDE(__start_log_dynamic_data = .);
        KEEP(*(SORT(.log_dynamic_data*)))
        PROVIDE(__stop_log_dynamic_data = .);
      } > RAM
      .fs_data :
        PROVIDE(__start_fs_data = .);
        KEEP(*(.fs_data))
        PROVIDE(__stop_fs_data = .);
      } > RAM
    } INSERT AFTER .data;
    SECTIONS
      .mem_section_dummy_rom :
      .crypto_data :
        PROVIDE(__start_crypto_data = .);
        KEEP(*(SORT(.crypto_data*)))
        PROVIDE(__stop_crypto_data = .);
      } > FLASH
      .log_const_data :
        PROVIDE(__start_log_const_data = .);
        KEEP(*(SORT(.log_const_data*)))
        PROVIDE(__stop_log_const_data = .);
      } > FLASH
        .nrf_queue :
        PROVIDE(__start_nrf_queue = .);
        KEEP(*(.nrf_queue))
        PROVIDE(__stop_nrf_queue = .);
      } > FLASH
      .dfu_trans :
        PROVIDE(__start_dfu_trans = .);
        KEEP(*(SORT(.dfu_trans*)))
        PROVIDE(__stop_dfu_trans = .);
      } > FLASH
        .nrf_balloc :
        PROVIDE(__start_nrf_balloc = .);
        KEEP(*(.nrf_balloc))
        PROVIDE(__stop_nrf_balloc = .);
      } > FLASH
        .svc_data :
        PROVIDE(__start_svc_data = .);
        KEEP(*(.svc_data))
        PROVIDE(__stop_svc_data = .);
      } > FLASH
      .sdh_ble_observers :
        PROVIDE(__start_sdh_ble_observers = .);
        KEEP(*(SORT(.sdh_ble_observers*)))
        PROVIDE(__stop_sdh_ble_observers = .);
      } > FLASH
      .sdh_state_observers :
        PROVIDE(__start_sdh_state_observers = .);
        KEEP(*(SORT(.sdh_state_observers*)))
        PROVIDE(__stop_sdh_state_observers = .);
      } > FLASH
      .sdh_stack_observers :
        PROVIDE(__start_sdh_stack_observers = .);
        KEEP(*(SORT(.sdh_stack_observers*)))
        PROVIDE(__stop_sdh_stack_observers = .);
      } > FLASH
      .sdh_req_observers :
        PROVIDE(__start_sdh_req_observers = .);
        KEEP(*(SORT(.sdh_req_observers*)))
        PROVIDE(__stop_sdh_req_observers = .);
      } > FLASH
      .sdh_soc_observers :
        PROVIDE(__start_sdh_soc_observers = .);
        KEEP(*(SORT(.sdh_soc_observers*)))
        PROVIDE(__stop_sdh_soc_observers = .);
      } > FLASH
    } INSERT AFTER .text
    INCLUDE "nrf_common.ld"
    I have tried flashing BL+SD, and it does advertise.
    I also tried BL+SD+Settings+ APP, and Bootloader advertises in this occasion too, when i switch it using a button, to put it into bootloader mode.
    And, i ALSO tried SD+APP, and the application works.
    The problem is, when the application is flashed along with the bootloader, it does not advertise, i can still see the blue LED, (but it does not blink, which is how i know whether it is advertising or not).
    Firstly, you should use the nRF Connect app to see if the device is advertising or not, the LED not blinking can be a consequence of something else. You should check if the device is advertising in bootloader mode.
    You can also enable the logging option via RTT and copy the logs in here.
    You should also not do a reset in each programming stage, just run a single reset at the end and see if that helps.
    Best Regards,
    Marjeris
  • I have tried using the nrfConnect app, it does not advertise.
    I tried --reset at the end, and it does not make any difference.
  • Could you post the debug logs here please? Need to know what is going on. Just to have things clear, can you post the commands you are using now? It is not clear from you answer if you tried a --reset at the end of each program line, or if you program SD+BT+app+settings and then ran
    nrfjprog --reset
    at the end.
    Marjeris
