nRF52840 RTC example, multiple definition of `RTC1_IRQHandler'
Hi. I am trying to add a RTC to my ble project. I copied all the simple code from the RTC example, and set all the sdk_config.h settings to match.
As per usual millions of issues. I have waded through most of the build errors. I have now got to the this issue;
1> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\libraries\timer/app_timer.c:907: multiple definition of `RTC1_IRQHandler'
I have had a good search around and have no idea what the issue is here. Have tried loads of combinations of the config settings, but these below are the current ones (not building).
// <e> NRFX_RTC_ENABLED - nrfx_rtc - RTC peripheral driver
#ifndef NRFX_RTC_ENABLED
#define NRFX_RTC_ENABLED 1
// <q> NRFX_RTC0_ENABLED  - Enable RTC0 instance
#ifndef NRFX_RTC0_ENABLED
#define NRFX_RTC0_ENABLED 0
// <q> NRFX_RTC1_ENABLED  - Enable RTC1 instance
#ifndef NRFX_RTC1_ENABLED
#define NRFX_RTC1_ENABLED 0
// <q> NRFX_RTC2_ENABLED  - Enable RTC2 instance
#ifndef NRFX_RTC2_ENABLED
#define NRFX_RTC2_ENABLED 0
// <e> RTC_ENABLED - nrf_drv_rtc - RTC peripheral driver - legacy layer
#ifndef RTC_ENABLED
#define RTC_ENABLED 1
// <o> RTC_DEFAULT_CONFIG_FREQUENCY - Frequency  <16-32768>
#ifndef RTC_DEFAULT_CONFIG_FREQUENCY
#define RTC_DEFAULT_CONFIG_FREQUENCY 32768
// <q> RTC_DEFAULT_CONFIG_RELIABLE  - Ensures safe compare event triggering
#ifndef RTC_DEFAULT_CONFIG_RELIABLE
#define RTC_DEFAULT_CONFIG_RELIABLE 0
// <o> RTC_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef RTC_DEFAULT_CONFIG_IRQ_PRIORITY
#define RTC_DEFAULT_CONFIG_IRQ_PRIORITY 7
// <q> RTC0_ENABLED  - Enable RTC0 instance
#ifndef RTC0_ENABLED
#define RTC0_ENABLED 0
// <q> RTC1_ENABLED  - Enable RTC1 instance
#ifndef RTC1_ENABLED
#define RTC1_ENABLED 1
// <q> RTC2_ENABLED  - Enable RTC2 instance
#ifndef RTC2_ENABLED
#define RTC2_ENABLED 0
Any help would be appreciated.
Thanks
