I try to open ANT+ channel and make sure the status is searching or tracking,
but if I use pstorage to update flash in the same time,
It will response timeout on update flash result...
P.S. I used S310 and NRF 51422 solution
The idea behind pstorage is to be able to get assigned time to do the flash operations outside the radio events from the softdevice. Are you doing continuous scanning with the ANT node? If you keep it in scanning mode it will not be assigned time, so please try to toggle the scan event.
Hi Asbjørn
I am having similar issues as well. In continuous rx scan mode, pstorage store will mostly work, but occasionally crash (the system hangs without tripping watchdog)!.
Can you please recommend or give us an example on how to toggle the scan event?
@Zer0page: May I ask you to create your own case here on DevZone and state which chip revision you use, SDK, example code and details to what you are doing. We prefer to have a one question one answer and avoid multithreads.
