nrf51822 - heart rate monitor demo compilation problems.
Dear all, I am following the user guide nRF51822_Evaluation_Kit User_Guide v1.2.pdf When I try to compile the example C:\Keil_v5\ARM\Device\Nordic\nrf51822\Board\pca10001\s110\ble_app_hrs\arm\ble_app_hrs.uvproj using the Keil_v5 evaluation tool. I got these errors :
Build target 'nrf51822_xxaa_s110 (256K)'
compiling system_nrf51.c...
..\..\..\..\..\Include\nrf51.h(119): error:  #5: cannot open source input file "core_cm0.h": No such file or directory
  #include "core_cm0.h"                               /*!< Cortex-M0 processor and core peripherals                              */
..\..\..\..\..\Source\templates\system_nrf51.c: 0 warnings, 1 error
compiling main.c...
..\main.c: 0 warnings, 1 error
compiling battery.c...
..\battery.c: 0 warnings, 1 error
compiling led.c...
..\led.c: 0 warnings, 1 error
compiling app_timer.c...
..\..\..\..\..\Source\app_common\app_timer.c: 0 warnings, 1 error
compiling softdevice_handler.c...
..\..\..\..\..\Source\sd_common\softdevice_handler.c: 0 warnings, 1 error
compiling app_trace.c...
..\..\..\..\..\Source\app_common\app_trace.c: 0 warnings, 1 error
compiling simple_uart.c...
..\..\..\..\..\Source\simple_uart\simple_uart.c: 0 warnings, 1 error
compiling pstorage.c...
..\..\..\..\..\Source\app_common\pstorage.c: 0 warnings, 1 error
compiling app_button.c...
..\..\..\..\..\Source\app_common\app_button.c: 0 warnings, 1 error
compiling app_gpiote.c...
..\..\..\..\..\Source\app_common\app_gpiote.c: 0 warnings, 1 error
compiling ble_error_log.c...
..\..\..\..\..\Source\ble\ble_error_log.c: 0 warnings, 1 error
compiling ble_debug_assert_handler.c...
..\..\..\..\..\Source\ble\ble_debug_assert_handler.c: 0 warnings, 1 error
".\_build\ble_app_hrs.axf" - 13 Error(s), 0 Warning(s).
Target not created.
I guess I could try to fix the path of the referenced library
C:\Keil_v5\ARM\Pack\ARM\CMSIS\4.2.0\CMSIS\Include\core_cm0.h
C:\Keil_v5\ARM\Device\Nordic\nrf51422\Include\nrf51.h
anyway, I would like to know what would be the cleanest way to fix it.
Thanks and Kind Regards,
  • Have you tried to reinstall the Keil MDK-ARM? Did you follow the steps in the quick start guide?
  • Hi, An important message from Keil is that from version 5.12 of Keil IDE projects in the old format (.uvproj) are not supported any more (in more details are supported only with the Legacy Installer which copies certain files into specified locations). Projects in the new format (.uvprojx) should be used instead. If someone after all wants to use the old format (.uvproj) in Keil 5.12 or higher, should install, along with nRF_DeviceFamilyPack, the MDKCM Add-On Installer from: www.keil.com/mdk5/legacy.
  • It works fine using .uvprojx Thanks
