how to drive spi CS line low for 32 bits.
Can you please direct me to the document that explains about generating more than 8 bits of clock in SPI and keeping CS line low for that entire period.
Also, if i have to send two 16bit data, would i have to send them in lots of 8bit ? or i can send them as 16bits using nrf_drv_spi_transfer API?
I am modifying the SPI example found under SDK15/example/peripheral/spi.
And i have to achieve the sequence attached in the image.
Thank you
    You are not waiting for the SPI transfer to be finished (missing while(!spi_xfer_done)).
    Since you initialize the SPI driver with a spi_handler set, this will set the driver into non-blocking mode. If you want blocking mode, set the handler to NULL when initializing the driver.
    Håkon
  • Hi Hakon,
    I need to enable pull ups on SPI lines. Datasheet of IC recommends to use 10K pull up resistors on SPI lines . How can I enable internal pull ups on SPI lines ? I have used  nrf_gpio_cfg_output API to enable PULL UPS by changing its definition in nrf_gpio.h like this :
    __STATIC_INLINE void nrf_gpio_cfg_output(uint32_t pin_number)
        nrf_gpio_cfg(
            pin_number,
            NRF_GPIO_PIN_DIR_OUTPUT,
            NRF_GPIO_PIN_INPUT_DISCONNECT,
            NRF_GPIO_PIN_PULLUP,
            NRF_GPIO_PIN_S0S1,
            NRF_GPIO_PIN_NOSENSE);
    Is this the right way to do so or there is any other better way also??
     * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include "nrf_drv_spi.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "boards.h"
    #include "app_error.h"
    #include <string.h>
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define SPI_INSTANCE  0 /**< SPI instance index. */
    static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
    static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
    static uint32_t       m_tx_buf4= 0b10000000001100000000000000000000;    //0X80BC
    //static uint16_t       m_tx_buf5= 0b;
    static uint16_t       m_rx_buf1[2];    /**< RX buffer. */
    static const uint8_t  m_length1 = 4;        /**< Transfer length. */
     * @brief SPI user event handler.
     * @param event
    void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                           void *                    p_context)
        spi_xfer_done = true;
        NRF_LOG_INFO("Transfer completed.");
        if (m_rx_buf1[0] != 0)
            NRF_LOG_INFO(" Received:");
            NRF_LOG_HEXDUMP_INFO(m_rx_buf1, strlen((const char *)m_rx_buf1));
            nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
            spi_config.ss_pin   = SPI_SS_PIN;
            spi_config.miso_pin = SPI_MISO_PIN;
            spi_config.mosi_pin = SPI_MOSI_PIN;
            spi_config.sck_pin  = SPI_SCK_PIN;
            spi_config.mode = NRF_DRV_SPI_MODE_2;
            nrf_gpio_cfg_output(SPI_SS_PIN);
            nrf_gpio_cfg_input(SPI_MISO_PIN, NRF_GPIO_PIN_PULLUP);
            nrf_gpio_cfg_output(SPI_MOSI_PIN);
            nrf_gpio_cfg_output(SPI_SCK_PIN);
            APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
           NRF_LOG_INFO("SPI example started.");
            memset(m_rx_buf1, 0, m_length1);
            spi_xfer_done = false;
              //Send 80H to BCH to read power factor from BCH register
            APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &m_tx_buf4, m_length1, m_rx_buf1, m_length1));
             while (!spi_xfer_done)
                __WFE();
            NRF_LOG_FLUSH();
            bsp_board_led_invert(3);
            nrf_delay_ms(200);
          //  memset(m_rx_buf1, 0, m_length1);
          //  spi_xfer_done = false;
           // APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &m_tx_buf5, m_length1, m_rx_buf1, m_length1));
          //    while (!spi_xfer_done)
          //      __WFE();
          //  NRF_LOG_FLUSH();
          //  bsp_board_led_invert(2);
          //  nrf_delay_ms(200);
    I am sorry for the late reply.
    You cannot enable pull up on a gpio configured as output. If you need a pull-resistor on a GPIO configured as output, you can either set the level (1 or 0), or add an external pull-resistor.
    Håkon
  • Hi Hakon,
    I am still struggling to produce correct SPI timings . Below is the actual SPI timing sent to me by an Application Engineer from MICROCHIP. I need to replicate the same using nrf52840 chip :
    I am getting these SPI timings using the same operation as in above image through nrf52840 chip .
    Can you identify what is going wrong with my attached firmware ????
    Any kind of help or suggestion will be appreciated . We are really running late now on our project .
    #include "boards.h"
    #include <string.h>
    static uint16_t       m_tx_buf4= 0b1000000000110000;    //0X30H
    static uint16_t       m_tx_buf5= 0b0000000000000000;
    static uint8_t       m_rx_buf[2];    /**< RX buffer. */
    static const uint8_t  m_length = 4;        /**< Transfer length. */
     * @param event
                           void *                    p_context)
        if (m_rx_buf[0] != 0)
            NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
            spi_config.mode = NRF_DRV_SPI_MODE_0;
            while(1){
            memset(m_rx_buf, 0, m_length);
            APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &m_tx_buf4, m_length, m_rx_buf, m_length));
                __WFE();
            NRF_LOG_FLUSH();
            nrf_delay_ms(200);
    Arshdeep
    1. You are overflowing your buffer (m_rx_buffer) by 2 bytes, as the buffer is declared as 2 byte and you are receiving 4 bytes. This is _very crucial_ that you fix.
    2. You are no longer switching SPI mode as per the spec for the sensor you are communicating with.
    Håkon
