SPI Master Clock mapping problem
I am trying to use the SPI with a sensor on our PCB.
Based on the SPIM example, I changed the used pins to match our configuration, where the clock (spi_config.sck_pin) is routed to pin GPIO-9 (P0.09).
For some reason, when setting the SPIM to use this pin, there is no clock signal we can see there. When setting the sck_pin to another pin, such as 3, 22 or 31 we can see the clock signal there.
Is there any restriction for using GPIO 9 (for the clock or any other SPIM signal)? Please note that we are not using NFC in our project.
Any advice will be appreciated.
Thanks
Shay
