Design Review of NRF51822-QFAA board
Greetings from India!
I would like to have my design review by your engineers or any concerned person in the related field. The design is not yet complete but the reference layout is taken from here.
I am using inverted F antenna with default passive pi-network as given in the reference layout.
I have attached the gerbers below at your perusal for review.
Please provide me with the detailed analysis as I am a beginner in the RF world. Also I do not have any spectrum analyzer to carry out any necessary testing. If possible please provide me with a correct design(preferred in EagleCAD) .
Below is the snapshot of the board designed in Eagle.
Hoping to hear from you soon.
Tracker.zip
  • The balun question is moot.  You should use the balun since it will give a predictable result unlike a lumped element balun. So you should use the chip balun for either antenna.
    On the F antenna, if you plan on using it you should model it or really trust the source that they modeled it. Sonnet is an easy app to use and the free version should take care of it.
    If you still feel like you want a printed antenna without trusting your source for the F and modeling it yourself, then copy either the F-meander hybrid that both Nordic and TI have used. TI even has a whitepaper out on it. Then you are getting an antenna from a reliable source that if duplicated faithfully will likely work.
    If none of the above options appeal to you then hire an RF engineer since you will have some matching to do with an unknown antenna and a lumped element balun.
  • Thanks for your valuable suggestion. I just updated the board layout a bit.
    I plan to use the balun, for now I am sticking with the discrete balun network provided here
    In the design I just added a shunt capacitor [C25] for tuning.
    The thick line in the design from the feed of the antenna to the common point of C6,L3 has a width of 1.42mm and clearance from the TOP GND plane is 0.254mm. However the bottom GND plane is present under that line.
    As the board thickness will be 1.6mm,  the impedance of the line becomes 50ohm.
    I got the value from Saturn PCB Toolkit.
    Screenshot of Saturn Toolkit:
    Saturn PCB Toolkit
    Am I going right ?
    What else is needed to be considered?
    Please help!
    Your design looks good now, you should be good to go.
    Andreas
  • Thanks  for your reply. But I am worried about the F antenna I am using. I haven't seen any proper results or post regarding the successful use of the inverted antenna with nrf51822.
    So I again modified my design and copied the meandered antenna from the official NRF51822 EK Board. I have attached the zip provided by Nordic.
    nRF51822 Evaluation Kit - Hardware files 2_0.zip
    I copied the design from the PCA10001 folder.
    Here goes my updated design.
    Can someone help if this is good ?
    Or, the F antenna is better to go with in terms of efficiency?
    Please provide me corrections(if any).
    Thank you in advance for taking out some time to review the design.
