Write in flash + re-init problem
I am currently running into an issue with nrf51822. I am trying to write in flash a flag which defines the device I use. Indeeed, the device on which the code will run can have 3 modes & a user can modify this mode with a command sent through UART. When the command has been run, the system should re-init to modify the UART, advertising or conn_params settings.
There is no particular problem with initialization but when the UART command is run, the system stops. Indeed, the write command is blocked in an infinite loop, waiting for the NRF_EVT_FLASH_OPERATION_SUCCESS event.
I join the code run at initialization & the function used to write in flash, the function run when the UART command has been received just calls the init function to re-init all settings with the new device mode.
void system_init(void)
    uint32_t err_code;
    softdevice_sys_evt_handler_set(sys_evt_handler);
    if (ble_device_type == DEFAULT)
        ble_device_type = WBLE;
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, NULL);
    if (ble_device_type == WBLE)
        db_discovery_init();
    uart_init();
    ble_stack_init();
    //Function used to write the device type flag in flash memory
    wat_write_flash_type((uint8_t )ble_device_type);
    else if (ble_device_type == UART_MODULE || ble_device_type == WBEACON)
        gap_params_init();
        services_init();
        if (ble_device_type == UART_MODULE)
            advertising_init();
            conn_params_init();
            err_code = ble_advertising_start(BLE_ADV_MODE_SLOW);
        else if (ble_device_type == WBEACON)
            err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
uint8_t wat_write_flash_type(uint8_t type)
    uint32_t status = NRF_ERROR_BUSY;
    uint8_t d_type[4];
    d_type[0] = type;
    d_type[1] = 0;
    d_type[2] = 0;
    d_type[3] = 0;
    do
        status = sd_flash_write((uint32_t *)TYPE_LOCATION, (uint32_t*)d_type, 1);
    while (status == NRF_ERROR_BUSY);
    flashBusy = true;
    while(flashBusy)
        sd_app_evt_wait();
    if(status != NRF_SUCCESS)
        return 1; // Error
    return 0;
I also join the callback used to trigger the event.
void sys_evt_handler(uint32_t evt)
    switch(evt)
        case NRF_EVT_FLASH_OPERATION_SUCCESS:
            flashBusy = false;
        case NRF_EVT_FLASH_OPERATION_ERROR:
It seems that when I try to re-init, the system is in INVALID_STATE (that is the error code returned by the function uart_init).
Do not hesitate to ask for further information if needed.
    If you have already initialized UART, you will get INVALID_STATE error if you try to init it again. You either need to uninit the old initialization before re-init, or use the old initialized UART interface.
    Jørgen
  • Hi Jorgen,
    thank you for your answer, I figured out that I could not init the UART twice, same with BLE stack & other init functions, how to uninit those ?
    I also tried something else, instead of trying to re-init, I change the device mode & write the new mode in flash, reset the device & then init with the new mode but I have some issues trying to write in flash. Indeed, when the device receive the UART command to change its mode, a flag is set to 1 & in the main function, when this flag is set, I try to write in flash the new mode & then reset the device but writing to flash fails, the program waits for NRF_EVT_FLASH_OPERATION_SUCCESS which never happens.
    I do not understand pretty well this behaviour, I guess the sys_evt_handler callback is never called to trigger this event but I am not sure and i do not know why either.
    Nicolas Hell.
  • Most drivers/libraries have uninit functions. In most cases you should be able to reuse the initialized peripherals without re-initialization.
    Are you triggering the Flash write from interrupt context or main context? Have you tried debugging the application to see if it gets past the while loop where you call sd_flash_write?
  • I was at first trying to use it from interrupt context and figured out it was not working so I changed that and now  I trigger the Flash write in main context. I identified the problem I think, in my function which processes the UART command received, I sent again some debug information on same UART so I was trigerring a new interrupt which caused the write in flash to fail.
    Now I am able to write in flash & change the mode as I wanted, I just have another issue but I do not think it is related to this one, I guess it is due to bad behaviour in uart_event_handle function in different mode, I have to go check this out
  • Well in fact I am running into another issue which I do not understand at all, I managed to get the desired behaviour once, and now, nothing works at all, the program cannot write in flash at the specified address, I really do not know why.
    I tried to erase all in the device then re-flash the SoftDevice & application but it does not work anymore, I can write in flash the first time I run the program (I write at init the default mode) but after that, I cannot do it again it seems
