Power consumption using PWM powering a Piezo buzzer
Currently I am sounding a simple beep on and off sound with a Piezo Buzzer on the nRF52832 and using the power profiler, it is consuming approx 713.323 μA, I was wondering it that sound a bit on the high side, and if so, what kind of recommendations I should be following to try and lower this output.
Thanks in advance for your help.
Jason Anderssen
    It is difficult to say weather that is high or not without knowing more about the buzzer and how you drive it. Can you provide a bit more info?  Also, what is the current consumption of your device if you disconnect the buzzer but keeps everything else the same?
  • Hi Einar,
    Thanks for your reply, my code is as follows, basically I create a timer, so every 1/2 a second, it calls play_buzzer_alert, but before the timer starts, I call the start_buzzer_alert() once.  Before the sounds, I am running at approx 14μA, hope that clarifies things a bit better.  I am always happy to hear a better way to do the following if you have one.
    static void start_buzzer_alert()
        if (buzzer_emergency_active)
            return;
    #ifdef DEVELOPMENT_BOARD
        app_pwm_config_t pwm_alert_cfg = APP_PWM_DEFAULT_CONFIG_1CH(1000L, 31);
        uint8_t pwm_alert_channel = 0;
    #else
        app_pwm_config_t pwm_alert_cfg = APP_PWM_DEFAULT_CONFIG_2CH(1000L, SPEAKER_HZ, SPEAKER_2);
        uint8_t pwm_alert_channel = 1;
        pwm_alert_cfg.pin_polarity[1] = APP_PWM_POLARITY_ACTIVE_HIGH;
        app_pwm_init(&PWM1, &pwm_alert_cfg, pwm_ready_callback);
        app_pwm_enable(&PWM1);
        alert_buzzer_value = 50;
        buzzer_play_count = 10;
        buzzer_emergency_active = true;
        while (app_pwm_channel_duty_set(&PWM1, pwm_alert_channel, alert_buzzer_value) == NRF_ERROR_BUSY);
    static void play_buzzer_alert()
        if (beacon_state != MODE_EMERGENCY)
            return;
        if (alert_buzzer_value == 0) {
        } else {
            alert_buzzer_value = 0;
        if (buzzer_play_count == 0) {
        } else {
            // for now we do continuing beeps, as if we try and uninit here, it seems to cause issues in the beacon.
            //buzzer_play_count--;
    #else
    static void stop_buzzer_alert()
        if (buzzer_emergency_active == false)
            return;
        if (beacon_state == MODE_EMERGENCY)
            return;
        app_pwm_disable(&PWM1);
        app_pwm_uninit(&PWM1);
        buzzer_play_count = 0;
        buzzer_emergency_active = false;
    Thanks
    Jason
  • I see. The current consumption does not seem high to me. The clock is running, and you have one timer running (app_pwm) and that two alone should give you about 500 μA. Then you have the current consumption of the buzzer itself. That can vary greatly, but 200 μA is not a strange number, so all in all a current consumption of about 700 μA seems reasonable.
