Which example projects are compatible with s110 v7 for nRF51822? I keep running into samples requiring "Legacy Keil" to be installed.
I just want a clean s110 v7 example that can send and receive, like an LED-Button example.
is should be in the sdk v6.1. You can also get example from here embeddedsoftdev.blogspot.ca/.../ehal-nrf51.html
It seems nAN-36 is mostly obsolete even though it still shows in downloads, and instead look at the SDK6.1 documentation for the Examples (as mentioned in answer above). The SDK6.1 doc is much more detailed in everything except how to set up the compilers (Keil or Eclipse/GCC).
