SPI master transaction SDK V10.0
Hi everyone,
I used SPI interface to access a external flash with page size 256 bytes.
I found I can't access full page, because the maximum of one SPI transaction is 255 bytes.
I need 260 bytes (include command and data) in one SPI transaction to access full page, is it possible to use SPI transaction more than 255 bytes?
Thank you!
    Unfortunately the SPI driver is limited to a length parameter of size uint8_t. This limit comes from the MAXCNT register size of 8 bit on SPIM peripheral (with EasyDMA support) on nRF52832.
    If using legacy SPI peripheral on nRF51822, you should be able to extend the length parameters to 16 bit.
    I have attached modified drivers that you can try. Note that there is not guards preventing it from being used with SPIM peripheral, so please use with care.
    /* Copyright (c) 2015 Nordic Semiconductor. All Rights Reserved.
     * The information contained herein is property of Nordic Semiconductor ASA.
     * Terms and conditions of usage are described in detail in NORDIC
     * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
     * Licensees are granted free, non-transferable use of the information. NO
     * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
     * the file.
    #include "nrf_drv_spi.h"
    #include "nrf_drv_common.h"
    #include "nrf_gpio.h"
    #include "nrf_assert.h"
    // This set of macros makes it possible to exclude parts of code when one type
    // of supported peripherals is not used.
    #if ((SPI0_ENABLED == 1 && SPI0_USE_EASY_DMA == 1 && defined(NRF52)) || \
         (SPI1_ENABLED == 1 && SPI1_USE_EASY_DMA == 1) || \
         (SPI2_ENABLED == 1 && SPI2_USE_EASY_DMA == 1))
        #define SPIM_IN_USE
    #if ((SPI0_ENABLED == 1 && SPI0_USE_EASY_DMA == 0) || \
         (SPI0_ENABLED == 1 && defined(NRF51))         || \
         (SPI1_ENABLED == 1 && SPI1_USE_EASY_DMA == 0) || \
         (SPI2_ENABLED == 1 && SPI2_USE_EASY_DMA == 0))
        #define SPI_IN_USE
    #if (defined(SPIM_IN_USE) && defined(SPI_IN_USE))
        // SPIM and SPI combined
        #define CODE_FOR_SPIM(code) if (p_instance->use_easy_dma) { code }
        #define CODE_FOR_SPI(code)  else { code }
    #elif (defined(SPIM_IN_USE) && !defined(SPI_IN_USE))
        // SPIM only
        #define CODE_FOR_SPIM(code) { code }
    #elif (!defined(SPIM_IN_USE) && defined(SPI_IN_USE))
        // SPI only
        #define CODE_FOR_SPI(code)  { code }
    #else
        #error "Wrong configuration."
    // Control block - driver instance local data.
    typedef struct
        nrf_drv_spi_handler_t handler;
        nrf_drv_state_t       state;
        volatile bool         transfer_in_progress;
        // [no need for 'volatile' attribute for the following members, as they
        //  are not concurrently used in IRQ handlers and main line code]
        uint8_t         ss_pin;
        uint8_t         orc;
        uint16_t         tx_buffer_length;
        uint16_t         rx_buffer_length;
        uint16_t         bytes_transferred;
        uint8_t const * p_tx_buffer;
        uint8_t       * p_rx_buffer;
        bool tx_done : 1;
        bool rx_done : 1;
    } spi_control_block_t;
    static spi_control_block_t m_cb[SPI_COUNT];
    static nrf_drv_spi_config_t const m_default_config[SPI_COUNT] = {
    #if (SPI0_ENABLED == 1)
        NRF_DRV_SPI_DEFAULT_CONFIG(0),
    #if (SPI1_ENABLED == 1)
        NRF_DRV_SPI_DEFAULT_CONFIG(1),
    #if (SPI2_ENABLED == 1)
        NRF_DRV_SPI_DEFAULT_CONFIG(2),
    ret_code_t nrf_drv_spi_init(nrf_drv_spi_t const * const p_instance,
                                nrf_drv_spi_config_t const * p_config,
                                nrf_drv_spi_handler_t handler)
        spi_control_block_t * p_cb  = &m_cb[p_instance->drv_inst_idx];
        if (p_cb->state != NRF_DRV_STATE_UNINITIALIZED)
        if (p_config == NULL)
            p_config = &m_default_config[p_instance->drv_inst_idx];
        p_cb->handler = handler;
        uint32_t mosi_pin;
        uint32_t miso_pin;
        // Configure pins used by the peripheral:
        // - SCK - output with initial value corresponding with the SPI mode used:
        //   0 - for modes 0 and 1 (CPOL = 0), 1 - for modes 2 and 3 (CPOL = 1);
        //   according to the reference manual guidelines this pin and its input
        //   buffer must always be connected for the SPI to work.
        if (p_config->mode <= NRF_DRV_SPI_MODE_1)
            nrf_gpio_pin_clear(p_config->sck_pin);
            nrf_gpio_pin_set(p_config->sck_pin);
        NRF_GPIO->PIN_CNF[p_config->sck_pin] =
            (GPIO_PIN_CNF_DIR_Output        << GPIO_PIN_CNF_DIR_Pos)
          | (GPIO_PIN_CNF_INPUT_Connect     << GPIO_PIN_CNF_INPUT_Pos)
          | (GPIO_PIN_CNF_PULL_Disabled     << GPIO_PIN_CNF_PULL_Pos)
          | (GPIO_PIN_CNF_DRIVE_S0S1        << GPIO_PIN_CNF_DRIVE_Pos)
          | (GPIO_PIN_CNF_SENSE_Disabled    << GPIO_PIN_CNF_SENSE_Pos);
        // - MOSI (optional) - output with initial value 0,
        if (p_config->mosi_pin != NRF_DRV_SPI_PIN_NOT_USED)
            mosi_pin = p_config->mosi_pin;
            nrf_gpio_pin_clear(mosi_pin);
            nrf_gpio_cfg_output(mosi_pin);
            mosi_pin = NRF_SPI_PIN_NOT_CONNECTED;
        // - MISO (optional) - input,
        if (p_config->miso_pin != NRF_DRV_SPI_PIN_NOT_USED)
            miso_pin = p_config->miso_pin;
            nrf_gpio_cfg_input(miso_pin, NRF_GPIO_PIN_NOPULL);
            miso_pin = NRF_SPI_PIN_NOT_CONNECTED;
        // - Slave Select (optional) - output with initial value 1 (inactive).
        if (p_config->ss_pin != NRF_DRV_SPI_PIN_NOT_USED)
            nrf_gpio_pin_set(p_config->ss_pin);
            nrf_gpio_cfg_output(p_config->ss_pin);
        m_cb[p_instance->drv_inst_idx].ss_pin = p_config->ss_pin;
        CODE_FOR_SPIM
            NRF_SPIM_Type * p_spim = p_instance->p_registers;
            nrf_spim_pins_set(p_spim, p_config->sck_pin, mosi_pin, miso_pin);
            nrf_spim_frequency_set(p_spim,
                (nrf_spim_frequency_t)p_config->frequency);
            nrf_spim_configure(p_spim,
                (nrf_spim_mode_t)p_config->mode,
                (nrf_spim_bit_order_t)p_config->bit_order);
            nrf_spim_orc_set(p_spim, p_config->orc);
            if (p_cb->handler)
                nrf_spim_int_enable(p_spim,
                    NRF_SPIM_INT_ENDTX_MASK | NRF_SPIM_INT_ENDRX_MASK |
                    NRF_SPIM_INT_STOPPED_MASK);
            nrf_spim_enable(p_spim);
        CODE_FOR_SPI
            NRF_SPI_Type * p_spi = p_instance->p_registers;
            nrf_spi_pins_set(p_spi, p_config->sck_pin, mosi_pin, miso_pin);
            nrf_spi_frequency_set(p_spi,
                (nrf_spi_frequency_t)p_config->frequency);
            nrf_spi_configure(p_spi,
                (nrf_spi_mode_t)p_config->mode,
                (nrf_spi_bit_order_t)p_config->bit_order);
            m_cb[p_instance->drv_inst_idx].orc = p_config->orc;
            if (p_cb->handler)
                nrf_spi_int_enable(p_spi, NRF_SPI_INT_READY_MASK);
            nrf_spi_enable(p_spi);
        if (p_cb->handler)
            nrf_drv_common_irq_enable(p_instance->irq, p_config->irq_priority);
        p_cb->transfer_in_progress = false;
        p_cb->state = NRF_DRV_STATE_INITIALIZED;
        return NRF_SUCCESS;
    void nrf_drv_spi_uninit(nrf_drv_spi_t const * const p_instance)
        ASSERT(p_cb->state != NRF_DRV_STATE_UNINITIALIZED);
        if (p_cb->handler)
            nrf_drv_common_irq_disable(p_instance->irq);
        #define DISABLE_ALL  0xFFFFFFFF
        CODE_FOR_SPIM
            if (p_cb->handler)
                nrf_spim_int_disable(p_spim, DISABLE_ALL);
            nrf_spim_disable(p_spim);
        CODE_FOR_SPI
            if (p_cb->handler)
                nrf_spi_int_disable(p_spi, DISABLE_ALL);
            nrf_spi_disable(p_spi);
        #undef DISABLE_ALL
        p_cb->state = NRF_DRV_STATE_UNINITIALIZED;
    #ifdef SPI_IN_USE
    // This function is called from IRQ handler or, in blocking mode, directly
    // from the 'nrf_drv_spi_transfer' function.
    // It returns true as long as the transfer should be continued, otherwise (when
    // there is nothing more to send/receive) it returns false.
    static bool transfer_byte(NRF_SPI_Type * p_spi, spi_control_block_t * p_cb)
        // Read the data byte received in this transfer and store it in RX buffer,
        // if needed.
        volatile uint8_t rx_data = nrf_spi_rxd_get(p_spi);
        if (p_cb->bytes_transferred < p_cb->rx_buffer_length)
            p_cb->p_rx_buffer[p_cb->bytes_transferred] = rx_data;
        ++p_cb->bytes_transferred;
        // Check if there are more bytes to send or receive and write proper data
        // byte (next one from TX buffer or over-run character) to the TXD register
        // when needed.
        // NOTE - we've already used 'p_cb->bytes_transferred + 1' bytes from our
        //        buffers, because we take advantage of double buffering of TXD
        //        register (so in effect one byte is still being transmitted now);
        //        see how the transfer is started in the 'nrf_drv_spi_transfer'
        //        function.
        uint16_t bytes_used = p_cb->bytes_transferred + 1;
        if (bytes_used < p_cb->tx_buffer_length)
            nrf_spi_txd_set(p_spi, p_cb->p_tx_buffer[bytes_used]);
            return true;
        else if (bytes_used < p_cb->rx_buffer_length)
            nrf_spi_txd_set(p_spi, p_cb->orc);
            return true;
        return (p_cb->bytes_transferred < p_cb->tx_buffer_length ||
                p_cb->bytes_transferred < p_cb->rx_buffer_length);
    #endif // SPI_IN_USE
    ret_code_t nrf_drv_spi_transfer(nrf_drv_spi_t const * const p_instance,
                                    uint8_t const * p_tx_buffer,
                                    uint16_t         tx_buffer_length,
                                    uint8_t       * p_rx_buffer,
                                    uint16_t         rx_buffer_length)
        ASSERT(p_tx_buffer != NULL || tx_buffer_length == 0);
        ASSERT(p_rx_buffer != NULL || rx_buffer_length == 0);
        if (p_cb->transfer_in_progress)
            return NRF_ERROR_BUSY;
        // Finish zero-length transfers immediately.
        if (tx_buffer_length == 0 && rx_buffer_length == 0)
            return NRF_SUCCESS;
        // Activate Slave Select signal, if it is to be used.
        if (p_cb->ss_pin != NRF_DRV_SPI_PIN_NOT_USED)
            nrf_gpio_pin_clear(p_cb->ss_pin);
        CODE_FOR_SPIM
            // EasyDMA requires that transfer buffers are placed in Data RAM region;
            // signal error if they are not.
            if ((p_tx_buffer != NULL && !nrf_drv_is_in_RAM(p_tx_buffer)) ||
                (p_rx_buffer != NULL && !nrf_drv_is_in_RAM(p_rx_buffer)))
                return NRF_ERROR_INVALID_ADDR;
            nrf_spim_tx_buffer_set(p_spim, p_tx_buffer, tx_buffer_length);
            nrf_spim_rx_buffer_set(p_spim, p_rx_buffer, rx_buffer_length);
            nrf_spim_event_clear(p_spim, NRF_SPIM_EVENT_ENDTX);
            nrf_spim_event_clear(p_spim, NRF_SPIM_EVENT_ENDRX);
            p_cb->tx_done = false;
            p_cb->rx_done = false;
            if (p_cb->handler)
                p_cb->transfer_in_progress = true;
            nrf_spim_event_clear(p_spim, NRF_SPIM_EVENT_STOPPED);
            nrf_spim_task_trigger(p_spim, NRF_SPIM_TASK_START);
            if (!p_cb->handler)
                while (!nrf_spim_event_check(p_spim, NRF_SPIM_EVENT_ENDTX) ||
                       !nrf_spim_event_check(p_spim, NRF_SPIM_EVENT_ENDRX)) {}
                // Stop the peripheral after transaction is finished.
                nrf_spim_task_trigger(p_spim, NRF_SPIM_TASK_STOP);
                while (!nrf_spim_event_check(p_spim, NRF_SPIM_EVENT_STOPPED)) {}
                    nrf_gpio_pin_set(p_cb->ss_pin);
        CODE_FOR_SPI
            p_cb->p_tx_buffer       = p_tx_buffer;
            p_cb->tx_buffer_length  = tx_buffer_length;
            p_cb->p_rx_buffer       = p_rx_buffer;
            p_cb->rx_buffer_length  = rx_buffer_length;
            p_cb->bytes_transferred = 0;
            if (p_cb->handler)
                nrf_spi_int_disable(p_spi, NRF_SPI_INT_READY_MASK);
            nrf_spi_event_clear(p_spi, NRF_SPI_EVENT_READY);
            // Start the transfer by writing some byte to the TXD register;
            // if TX buffer is not empty, take the first byte from this buffer,
            // otherwise - use over-run character.
                (tx_buffer_length > 0 ?  p_tx_buffer[0] : p_cb->orc));
            // TXD register is double buffered, so next byte to be transmitted can
            // be written immediately, if needed, i.e. if TX or RX transfer is to
            // be more that 1 byte long. Again - if there is something more in TX
            // buffer send it, otherwise use over-run character.
            if (tx_buffer_length > 1)
                nrf_spi_txd_set(p_spi, p_tx_buffer[1]);
            else if (rx_buffer_length > 1)
            // For blocking mode (user handler not provided) wait here for READY
            // events (indicating that the byte from TXD register was transmitted
            // and a new incoming byte was moved to the RXD register) and continue
            // transaction until all requested bytes are transferred.
            // In non-blocking mode - IRQ service routine will do this stuff.
            if (p_cb->handler)
                do {
                    while (!nrf_spi_event_check(p_spi, NRF_SPI_EVENT_READY)) {}
                } while (transfer_byte(p_spi, p_cb));
        return NRF_SUCCESS;
    static void finish_transfer(spi_control_block_t * p_cb)
        // If Slave Select signal is used, this is the time to deactivate it.
        // By clearing this flag before calling the handler we allow subsequent
        // transfers to be started directly from the handler function.
        p_cb->handler(NRF_DRV_SPI_EVENT_DONE);
    #ifdef SPIM_IN_USE
    static void irq_handler_spim(NRF_SPIM_Type * p_spim, spi_control_block_t * p_cb)
        ASSERT(p_cb->handler);
        if (nrf_spim_event_check(p_spim, NRF_SPIM_EVENT_STOPPED))
            finish_transfer(p_cb);
            if (nrf_spim_event_check(p_spim, NRF_SPIM_EVENT_ENDTX))
                p_cb->tx_done = true;
            if (nrf_spim_event_check(p_spim, NRF_SPIM_EVENT_ENDRX))
                p_cb->rx_done = true;
            if (p_cb->tx_done && p_cb->rx_done)
    #endif // SPIM_IN_USE
    #ifdef SPI_IN_USE
    static void irq_handler_spi(NRF_SPI_Type * p_spi, spi_control_block_t * p_cb)
        if (!transfer_byte(p_spi, p_cb))
    void SPI0_IRQ_HANDLER(void)
        #if (SPI0_USE_EASY_DMA == 1) && defined(NRF52)
            irq_handler_spim(NRF_SPIM0,
        #else
            irq_handler_spi(NRF_SPI0,
                &m_cb[SPI0_INSTANCE_INDEX]);
    #endif // (SPI0_ENABLED == 1)
    void SPI1_IRQ_HANDLER(void)
        #if (SPI1_USE_EASY_DMA == 1)
            irq_handler_spim(NRF_SPIM1,
        #else
            irq_handler_spi(NRF_SPI1,
                &m_cb[SPI1_INSTANCE_INDEX]);
    #endif // (SPI1_ENABLED == 1)
    void SPI2_IRQ_HANDLER(void)
        #if (SPI2_USE_EASY_DMA == 1)
            irq_handler_spim(NRF_SPIM2,
        #else
            irq_handler_spi(NRF_SPI2,
                &m_cb[SPI2_INSTANCE_INDEX]);
    #endif // (SPI2_ENABLED == 1)
    nrf_drv_spi.h
    Jørgen
