Bluetooth not connecting after inclusion of UART module in HID example. Its urgent.
I'm trying to combine hid keyboard with .../peripheral/uart example.
Only after the bluetooth connection is established between host (PC) & nrf DK, I want to continuously send data received from uart (connected to microcontroller) to host machine. This data needs to be sent in input report.
But if I merge the uart peripheral with hid keyboard, the bluetooth does not connect at all.
I have pasted the changes I have made to specific functions/ files. Can you check at your end?
void uart_error_handle(app_uart_evt_t * p_event)
	if (p_event->evt_type == APP_UART_DATA_READY)
		if(flag == 1)
			while (app_uart_get(&cr) != NRF_SUCCESS){};
			if (cr == '9')
				bsp_board_led_invert(1);
				nrf_delay_ms(500);
		//while (app_uart_put('?') != NRF_SUCCESS);
/*	else if (p_event->evt_type == APP_UART_TX_EMPTY)
    else if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
static void uart_init(void)
	uint32_t err_code;
	const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          0,/*RTS_PIN_NUMBER,*/
          0,/*CTS_PIN_NUMBER,*/
          UART_HWFC,
          false,
          NRF_UART_BAUDRATE_460800
    APP_UART_FIFO_INIT(&comm_params, UART_RX_BUF_SIZE, UART_TX_BUF_SIZE, uart_error_handle, APP_IRQ_PRIORITY_LOWEST, err_code);
    ret_code_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
			flag = 1;
            NRF_LOG_INFO("Disconnected");
            // Dequeue all keys without transmission.
            (void) buffer_dequeue(false);
            // Reset m_caps_on variable. Upon reconnect, the HID host will re-send the Output report containing the Caps lock state.
//            m_caps_on = false;
            // disabling alert 3. signal - used for capslock ON
            err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
			flag = 0;
            break; // BLE_GAP_EVT_DISCONNECTED
    bool erase_bonds;
    log_init();
//	Data_Init();
    timers_init();
    power_management_init();
    ble_stack_init();
    scheduler_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    sensor_simulator_init();
    conn_params_init();
    buffer_init();
    peer_manager_init();
    NRF_LOG_INFO("HID Keyboard example started.");
    timers_start();
    advertising_start(erase_bonds);
	uart_init();
    for (;;)
        idle_state_handle();
Rest things are just as is from ../peripheral/uart code.
I also made changes to sdkconfig.h
5355.sdk_config.h
