Blinky fails on PCA10059
Compiled Blinky client fails on Dongle PCA10059.
Precompiled version nRF5_SDK_15.2.0_9412b96/examples/ble_peripheral/ble_app_blinky/hex/ble_app_blinky_pca10059_s140.hex works correctly without problems.
But if I compile a version it fails totally. When powered up, dongle always goes to DFU-mode ( red led blinking ).
I have tried both package created and programmed with nrfutil and flashing directly using Seggers JLink. No difference.
Compiler: gcc version 5.4.1 20160919 (release) [ARM/embedded-5-branch revision 240496] (GNU Tools for ARM Embedded Processors
Package creation: nrfutil pkg generate --debug-mode --softdevice s140_nrf52_6.1.0_softdevice.hex --application _build/nrf52840_xxaa.hex app.zip --hw-version 52 --sd-req 0x00 --sd-id 0x00
Package write: nrfutil dfu usb_serial -pkg app.zip -p /dev/ttyACM0
Source was unmodified example in installation drectory.
Build directory: nRF5_SDK_15.2.0_9412b96/examples/ble_peripheral/ble_app_blinky/pca10059/s140/armgcc
    The --sd-id must match the ID of the Softdevice that you include in your update.
    So I tested with the following command to generate the packet:
    nrfutil pkg generate --debug-mode --softdevice ..\..\..\..\..\..\..\components\softdevice\s140\hex\s140_nrf52_6.1.0_softdevice.hex --application ..\_build\nrf52840_xxaa.hex --hw-version 52 --sd-req 0x00 --sd-id 0xAE dfu_test.zip
    (note that I used the gcc project, and generate the file from a folder within this folder (SDK15.2.0\examples\ble_peripheral\ble_app_blinky\armgcc\dfu_test, hence the ..\_build\nrf52840_xxaa.hex).
    Then I used the following command to program the device:
    nrfutil dfu usb_serial -pkg dfu_test.zip -p COM27
    And this works. When I tried to generate the packet with --sd-id 0x00, I can't run the application either. This is because the dongle doesn't think it has a softdevice after the DFU, and will assume it doesn't have all the necessary components to start the application, so it will stay in DFU mode.
    So try to change to --sd-id 0xAE
    Edvin
  • Thanks Edvin Slight smile
    I forgot to mention that I tried previously --sd-id 0xA9, it was the only documented code I could find, but that didn't work.
    That 0xAE works just perfect. :) :D
    It seems to me that PCA10059 versions of the Makefile should have nrfutil package creation and dfu operations rather than flash operations!! Slight smile for programming the dongle.
  • Glad to hear that it worked out.
    You can use "nrfutil pkg generate --help" to see the different softdevice IDs. If the softdevice that you are looking for isn't listed you probably just need to update your nrfutil version.
    Edvin
