hi,
I have been reading some posts regarding similar issues, but I am not able to nail down this one. I am trying to create a custom 128 UUID and associate some Service Data to this service. I would like to broadcast only (connection less).
I am using the code recommended in this post .
Does not seems to be any issues during the assignment of the new 128 UUID, until I call ble_advdata_set(). Performing such call end up in my app_error_handler(), the error number seems mean less
error_code = 3735928559
line_num = 1377
p_file_name const uint8_t* 0x20001d4c "src\\rem.c"
*p_file_name const uint8_t 115 's'
The code:
#define BLE_CYC_SERVICE_UUID 0x5424
uint32_t err_code;
ble_advdata_t advdata;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_uuid_t service_uuid;
uint8_t battery_data = 0x24;
ble_advdata_service_data_t service_data;
service_uuid.type = m_cy.uuid_type;
service_uuid.uuid = BLE_CY_SERVICE_UUID;
service_data.service_uuid = BLE_CYC_SERVICE_UUID;
service_data.data.size = sizeof(battery_data);
service_data.data.p_data = &battery_data;
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_FULL_NAME;
advdata.include_appearance = false;
advdata.flags.size = sizeof(flags);
advdata.flags.p_data = &flags;
advdata.service_data_count = 1;
advdata.p_service_data_array = &service_data;
advdata.uuids_more_available.uuid_cnt = 1; // new
advdata.uuids_more_available.p_uuids = &service_uuid;
err_code = ble_advdata_set(&advdata, NULL);
Second Try
Hi Petter,
First of all thank you for your help. Before going in to details let me list my full env.
- Windows 8.1
- SAGGER Jlink w/ SW version 4.92 and Jlink is using firmware v9 (This is the latest version)
- Eclipse 4.4 (Luna) and CDT extensions for GNU ARM
- GCC toolchain version 4.8 2014q2
- S110 v7
- SDK 6.1.0
- Part # QFAAG00
Just for the record I have been running some test code like ble_app_beacon to test the S110 v7 and it works without any issues.
No lets go back to the main subject. I built ble_apps_bls, but fails when executes this part returning an error = 12289. I set advdata.name_type = BLE_ADVDATA_NO_NAME
gap_params_init:
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
I tried your code as well, but it failed as well (I set advdata.name_type = BLE_ADVDATA_NO_NAME) :
gap_params_init:
err_code = sd_ble_gap_ppcp_set(&gap_conn_params)
I am not sure what else to try. Do I need to use nRFgo or other tool to setup something else? Is there any known issues with the chip rev that I have?
Thanks for your support.
P.S I attached 2 zip (all the images and map files), 1x Sagger log, 1 x Makefile files.
ble_app_template_128UUID-Makefile
Cheers Dan
