hi.....
can we able to flash the program in thingy via usb
is it possible?
i am using segger software sdk 15version
hi.....
is it possible?
Hi.
Yes, you can program the Thingy:52, but you need to use a nRF52-DK. This is because the Thingy:52 does not have a onboard debugger, USB is only for charging the Thingy:52.
In order to connect the Thingy:52 with a nRF52-DK you need a 10-pin cable.
See this post on how to connect them together. After they are connected, and you have flashed the Thingy FW, you can debug the code the same way as you would debug the code running on the nRF52-DK.
- Andreas
