nRF5 SDK for Mesh v2.2.0: Light Switch Demo - Where Next?
So I have successfully built & deployed the Light Switch Demo - and it works.
But where do we go next?
The documentation seems far too close-in focussed on the microscopic details of functions, types, etc - I can't see anything which gives a macroscopic overview of how to create a system.
It's like a car handbook which describes each cog in the gearbox in fine details - but doesn't tell you how to drive the car!
For example, the Server controls just 1 LED on the DK.
How would we expand that to give independent control of all 4 LEDs?
In BT Mesh terminology, I think that would mean making each LED an "Element" ?
So how would we instantiate these - as instances of the Generic On/Off model?
  • No,  solutions are not much help - they are just "giving a man a fish"
    What we need is proper fishing lessons!
  • Sorry for the delayed response. As it seems you have gone through the light switch demo with a provisioner, a client & a server & read the documentation, I would recommend the following:
    Take a look at the light switch proxy client & proxy server examples & use the video in next link to get acquainted with the nRF Mesh application (iOS & Android).
    Essentially, all you need to do in the app is to bind the appkey to the generic on/off models & set the publish & subscription addresses. This is, in my opinion, the easiest way to get started.
    Then, I would make a few changes to the proxy client example. I believe the button_event_handler function should look like this out of the box (please correct me if I am wrong, as I may have made changes to this function):
    static void button_event_handler(uint32_t button_number)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
        uint32_t status = NRF_SUCCESS;
        generic_onoff_set_params_t set_params;
        model_transition_t transition_params;
        static uint8_t tid = 0;
        /* Button 1: ON, Button 2: Off, Client[0]
         * Button 2: ON, Button 3: Off, Client[1]
        switch(button_number)
            case 0:
            case 2:
                set_params.on_off = APP_STATE_ON;
            case 1:
            case 3:
                set_params.on_off = APP_STATE_OFF;
        set_params.tid = tid++;
        transition_params.delay_ms = APP_CONFIG_ONOFF_DELAY_MS;
        transition_params.transition_time_ms = APP_CONFIG_ONOFF_TRANSITION_TIME_MS;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: ONOFF SET %d\n", set_params.on_off);
        switch (button_number)
            case 0:
            case 1:
                /* Demonstrate acknowledged transaction, using 1st client model instance */
                /* In this examples, users will not be blocked if the model is busy */
                (void)access_model_reliable_cancel(m_clients[0].model_handle);
                status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
                hal_led_pin_set(BSP_LED_0, set_params.on_off);
            case 2:
            case 3:
                /* Demonstrate un-acknowledged transaction, using 2nd client model instance */
                status = generic_onoff_client_set_unack(&m_clients[1], &set_params,
                                                        &transition_params, APP_UNACK_MSG_REPEAT_COUNT);
                hal_led_pin_set(BSP_LED_1, set_params.on_off);
        switch (status)
            case NRF_SUCCESS:
            case NRF_ERROR_NO_MEM:
            case NRF_ERROR_BUSY:
            case NRF_ERROR_INVALID_STATE:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Client %u cannot send\n", button_number);
                hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
            case NRF_ERROR_INVALID_PARAM:
                /* Publication not enabled for this client. One (or more) of the following is wrong:
                 * - An application key is missing, or there is no application key bound to the model
                 * - The client does not have its publication state set
                 * It is the provisioner that adds an application key, binds it to the model and sets
                 * the model's publication state.
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Publication not configured for client %u\n", button_number);
                ERROR_CHECK(status);
    As the documentation states, buttons 1 & 3 are used to turn the app state on, whereas buttons 2 & 4 turn the app state off. Buttons 1 & 2 then send an acknowledged message to the servers, whereas 3&4 send an un-acknowledged message. I would recommend taking a look at the button_event_handler function from mesh sdk v2.1.1 if you want to send group messages to a specific group:
            case 0:
            case 1:
                /* send unicast message, with inverted GPIO pin value */
                status = simple_on_off_client_set(&m_clients[button_number],
                                                  !hal_led_pin_get(BSP_LED_0 + button_number));
            case 2:
            case 3:
                /* send a group message to the ODD group, with inverted GPIO pin value */
                status = simple_on_off_client_set_unreliable(&m_clients[button_number],
                                                             !hal_led_pin_get(BSP_LED_0 + button_number),
                                                             GROUP_MSG_REPEAT_COUNT);
                if (status == NRF_SUCCESS)
                    hal_led_pin_set(BSP_LED_0 + button_number, !hal_led_pin_get(BSP_LED_0 + button_number));
        switch (status)
            case NRF_SUCCESS:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Cannot send - client %u is busy\n", button_number);
    I have another case here which could be interesting to see.
    I am working on an example that will be able to use multiple LEDs on a server. Currently, I still have a few issues that I am trying to iron out, but I will let you know when I am done.
    Kind Regards,
    Bjørn
  • Thanks for all that
    am I on the right lines of these being separate "Elements" in the BT Mesh lingo?
