nRF52 Button Characteristic Adding
Hi Everyone,
I am trying to add a characteristic in the BLE_UART project. I'm intending to use that characteristic to transmit the state of a button.
I have copy-pasted the button implementation from the BLE_BLINKY project. My buttons_leds_init() function looks like this :
bsp_event_t startup_event;
uint32_t err_code = bsp_init(LEDBUTTON_BUTTON, button_event_handler);
and the button_event_handler() function is this :
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
ret_code_t err_code;
switch (pin_no)
case LEDBUTTON_BUTTON:
NRF_LOG_INFO("Send button state change.");
err_code = ble_nus_on_button_change(m_conn_handle, &m_nus, button_action);
if (err_code != NRF_SUCCESS &&
err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
err_code != NRF_ERROR_INVALID_STATE &&
err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(pin_no);
Even though i tried to follow the same logic found in the button characteristic of the blinky project i can't seem to notify the central for button state changes and even further after trying to add some breakpoints the button_event_handler is never actually reached. So there is probably something i am missing in the button implementation. Probably some interrupt that happens once the button is pressed but i am unable to find it. So if someone could clarify this matter to me.
Thanks
     You need to register a BLE event observer using the NRF_SDH_BLE_OBSERVER macro. Example:
    ble_lbs_c_t instance;
    NRF_SDH_BLE_OBSERVER(anything, BLE_LBS_C_BLE_OBSERVER_PRIO,
                         ble_lbs_c_on_ble_evt, &instance);
    Take a look at ble_lbs.h in the ble_app_blinky example. See here for more documentation of the LED Button Service.
    Marjeris
