Hi,Nordic support
Circuit design: Unused I/O pins where can i found recommended I/O end terminal desing of unusing GPIO pins ? I'd need such as pull-down resistor...
Thanks.
Hi,Nordic support
Thanks.
If you have any unused GPIOs in your design, the proper way to handle these are are to disconnect the input buffer for those pins in firmware. This can be done in the PIN_CNF register, field INPUT.
Note that the reset value of all GPIOs is disconnected input buffer.
Best regards Håkon
HI, Håkon Alseth
Thanks for your res,. OK.If i setting the input_buffer in farmware,The GPIO pin is not used and do not connect anyting in GPIO circuit design. I was concerned about noise and ESD breakdown.
thanks
HI, Håkon Alseth
thanks
When input is disconnected what is the internal pull-down? Does the pull-down option assert on the inside of the disconnect switch or at the PAD that interfaces to rest of the board?
