NRF52832 - advertising data
About this example
https://github.com/NordicPlayground/nrf51-ble-tutorial-advertising
It´s advertising the data
 uint8_t                     data_response[] = "Many_bytes_of_data" with the MAC and RSSI
without connection.
How can advertising dynamic data without connection ?
For example, MAC, RSSI + some dynamic data ?
Is there some SES example ?
Thanks
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_beacon_main main.c
     * @ingroup ble_sdk_app_beacon
     * @brief Beacon Transmitter Sample Application main file.
     * This file contains the source code for an Beacon transmitter sample application.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nordic_common.h"
    #include "bsp.h"
    #include "nrf_soc.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "ble_advdata.h"
    #include "app_timer.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                  /**< A tag identifying the SoftDevice BLE configuration. */
    #define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
    #define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
    #define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
    #define APP_DEVICE_TYPE                 0x02                               /**< 0x02 refers to Beacon. */
    #define APP_MEASURED_RSSI               0xC3                               /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
    #define APP_COMPANY_IDENTIFIER          0x0059                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    #define APP_MAJOR_VALUE                 0x01, 0x02                         /**< Major value used to identify Beacons. */
    #define APP_MINOR_VALUE                 0x03, 0x04                         /**< Minor value used to identify Beacons. */
    #define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                            0x45, 0x56, 0x67, 0x78, \
                                            0x89, 0x9a, 0xab, 0xbc, \
                                            0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
    #define DEAD_BEEF                       0xDEADBEEF                         /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
    #define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                 /**< Position of the MSB of the Major Value in m_beacon_info array. */
    #define UICR_ADDRESS                    0x10001080                         /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
    static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
    static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
    static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
    static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
        APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                             // implementation.
        APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                             // manufacturer specific data in this implementation.
        APP_BEACON_UUID,     // 128 bit UUID value.
        APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
        APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
        APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                             // this implementation.
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in]   line_num   Line number of the failing ASSERT call.
     * @param[in]   file_name  File name of the failing ASSERT call.
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        uint32_t      err_code;
        ble_advdata_t advdata;
        uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
        ble_advdata_manuf_data_t manuf_specific_data;
        manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
        manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
        manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type             = BLE_ADVDATA_NO_NAME;
        advdata.flags                 = flags;
        advdata.p_manuf_specific_data = &manuf_specific_data;
        // Initialize advertising parameters (used when starting advertising).
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
        m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
        m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
        m_adv_params.duration        = 0;       // Never time out.
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
        ret_code_t err_code;
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for initializing logging. */
    static void log_init(void)
    /**@brief Function for initializing LEDs. */
    static void leds_init(void)
        ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
    /**@brief Function for initializing timers. */
    static void timers_init(void)
            nrf_pwr_mgmt_run();
    //Propaganda
    uint8_t Propaganda = 0;
    static void Set_AdvData()
        // Prepare the scan response manufacturer specific data packet
        ble_advdata_manuf_data_t  manuf_data_response;
        uint8_t                     data_response[] = {0x08,0x00,0x03,0x08,0x00,0x03,0x08,0x00,0x03};
        //Change Data Advertising..
        ++Propaganda;
        data_response[0]=Propaganda;
        data_response[1]=Propaganda;
        data_response[2]=Propaganda;
        data_response[3]=Propaganda;
        data_response[4]=Propaganda;
        data_response[5]=Propaganda;
        data_response[6]=Propaganda;
        data_response[7]=Propaganda;
        data_response[8]=Propaganda;
        data_response[9]=Propaganda;
        manuf_specific_data.company_identifier  = 0x0059;
        manuf_specific_data.data.p_data         = data_response;
        manuf_specific_data.data.size           = sizeof(data_response);
    // one-shot flag for setting adv data
    static volatile bool g_setAdvData = false;
    #define SYSTICK_COUNT_ENABLE        1
    #define SYSTICK_INTERRUPT_ENABLE    2
    uint8_t msTicks = 0; /* Variable to store millisecond ticks */
    /* SysTick interrupt Handler. */
    void SysTick_Handler(void)  {
         if(++msTicks == 5) {
             LEDS_INVERT(BSP_LED_1_MASK); /* light LED 2 very 1 second */
             g_setAdvData = true;
             msTicks = 0;
     * @brief Function for application main entry.
        // Initialize.
        log_init();
        timers_init();
        leds_init();
        power_management_init();
        ble_stack_init();
        advertising_init();
        // Start execution.
        NRF_LOG_INFO("Beacon example started.");
        advertising_start();
        uint32_t returnCode;
        returnCode = SysTick_Config(SystemCoreClock / 1000);
        // Enter main loop.
        for (;; )
           if(g_setAdvData) {
              Set_AdvData();
            idle_state_handle();
    Could you help me ? After a while, the software stop to make advertising...can you give me some tip ?
  • Hi again.
    Try this code:
    (The timer is set to 5 seconds instead of 5 ms)
    /** @file
    #include <stdint.h>
    #include "bsp.h"
        .adv_data =
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
                             // implementation.
        uint32_t      err_code;
        if (g_setAdvData)
            manuf_specific_data.data.p_data[3] = 0xED;
        ble_advertising_init();
            nrf_pwr_mgmt_run();
    //Propaganda
      sd_ble_gap_adv_stop(m_adv_handle);
        ++Propaganda;
    uint32_t msTicks = 0; /* Variable to store millisecond ticks */
         if(++msTicks == 5000) {
             msTicks = 0;
        // Initialize.
        log_init();
        timers_init();
        leds_init();
        ble_stack_init();
        advertising_init();
        // Start execution.
        // Enter main loop.
        for (;; )
           if(g_setAdvData) {
              advertising_init();
              //Set_AdvData();
    Hope this helps.
    - Andreas
  • Hi again.
    I apologize for any confusion I've caused, I assumed you used SDK 15.0, and I also had some help solving your issue, and I missed a crucial point regarding what that solution did with your function Set_AdvData().
     The solution i was gives uses advertising_init() to update your advertising counter instead of your Set_AdvData() function.
        uint32_t      err_code;
        if (g_setAdvData)
    Thats why it's commented out.
    Just remove the ble_advertising_init(); I'm unsure how that code snip found its way into the code.
    - Andreas
  • Andreas
    Sorry, i hadnt seen that you had change the advertising_init() to accept my Propaganda variable!
    Thanks
    It´s working! Thanks!
    Btw, i had to put
    if(++msTicks >5) {
    msTicks = 0;
    To trigger interrupt each 1 second...is that right ?
  • Hi.
    Try:
         if(++msTicks == 1000) {
             msTicks = 0;
    msTicks is milliseconds, so you need to set the if sentence equal to 1000 ms (which is 1 second)
    - Andreas
  • I find out that idle_state_handle() make systick interrupt occurs each 250ms...
  • Hi.
    You could use the method I proposed to edit advertising data, I'm unsure about your use of SysTick_Handler(), as mention in this question.
    I propose that you either use app timer library or Real Time Counter.
    - Andreas
