Questions about Interactive pyaci
I'm testing an interactive pyaci example in Mesh SDK v2.2.0 with two nRF52DK boards.
Interactive mesh provisioning and configuration example worked fine so I modified the element index of GenericOnOffServer to 1 in light switch sever (not proxy server).
That is,
#define ACCESS_ELEMENT_COUNT (2)  // line 93 in nrf_mesh_config_app.h
app_onoff_init(&m_onoff_server_0, 1));    // line 108 in main.c
and then, test it again as follows on interacitve ipython.
> db = MeshDB("database/example_database.json")
> p = Provisioner(device, db)
> p.scan_start()
# found a device
> p.scan_stop()
> p.provision(name="Light bulb")
# DevkeyAdd: {'devkey_handle': 8}
# AddrPublicationAdd: {'address_handle': 0}
> cc = ConfigurationClient(db)
> device.model_add(cc)
> cc.publish_set(8, 0)
> cc.composition_data_get()
# received composition data
  "pid": "0000",
  "vid": "0000",
  "cid": "0059",
  "elements": [
      "location": "0000",
      "models": [
          "modelId": "0000"
          "modelId": "0002"
      "index": 0
      "location": "0000",
      "models": [
          "modelId": "1000"
      "index": 1
  "crpl": 40,
  "features": {
    "proxy": 2,
    "relay": 0,
    "low_power": 2,
    "friend": 2
cc.appkey_add(0)
cc.model_app_bind(db.nodes[0].unicast_address+1, 0, mt.ModelId(0x1000))
gc = GenericOnOffClient()
device.model_add(gc)
gc.publish_set(0, 0)
gc.set(True)
Unfortunatelly,  LED doesn't blink.
I can understand calling publish_set(8,0) on ConfigurationClient object... devkey_handle is 8, address_handle is 0.
But I still can't understand about publish_set(0,0) on GenericOnOffClient object.
Does the first argument 0 mean application key that is bound to 0x1000 model id?
and second argument 0 mean address_handle same as setting on ConfigurationClient?
Are there any wrong settings? or do I have to call any other commands?
Kenji
