I'm testing an interactive pyaci example in Mesh SDK v2.2.0 with two nRF52DK boards.
Interactive mesh provisioning and configuration example worked fine so I modified the element index of GenericOnOffServer to 1 in light switch sever (not proxy server).
That is,
#define ACCESS_ELEMENT_COUNT (2) // line 93 in nrf_mesh_config_app.h
app_onoff_init(&m_onoff_server_0, 1)); // line 108 in main.c
and then, test it again as follows on interacitve ipython.
> db = MeshDB("database/example_database.json") > p = Provisioner(device, db) > p.scan_start() # found a device > p.scan_stop() > p.provision(name="Light bulb") # DevkeyAdd: {'devkey_handle': 8} # AddrPublicationAdd: {'address_handle': 0} > cc = ConfigurationClient(db) > device.model_add(cc) > cc.publish_set(8, 0) > cc.composition_data_get() # received composition data "pid": "0000", "vid": "0000", "cid": "0059", "elements": [ { "location": "0000", "models": [ { "modelId": "0000" }, { "modelId": "0002" } ], "index": 0 }, { "location": "0000", "models": [ { "modelId": "1000" } ], "index": 1 } ], "crpl": 40, "features": { "proxy": 2, "relay": 0, "low_power": 2, "friend": 2 } cc.appkey_add(0) cc.model_app_bind(db.nodes[0].unicast_address+1, 0, mt.ModelId(0x1000)) gc = GenericOnOffClient() device.model_add(gc) gc.publish_set(0, 0) gc.set(True)
Unfortunatelly, LED doesn't blink.
I can understand calling publish_set(8,0) on ConfigurationClient object... devkey_handle is 8, address_handle is 0.
But I still can't understand about publish_set(0,0) on GenericOnOffClient object.
Does the first argument 0 mean application key that is bound to 0x1000 model id?
and second argument 0 mean address_handle same as setting on ConfigurationClient?
Are there any wrong settings? or do I have to call any other commands?
Kenji
