FATFS example doesn't work ...
Hi ,
I'm trying to evaluate the FATFS example and unfortunately the statement disk_initialize(0) in main.c fails.
I'm using PCA10040, SDK 15.1, and switched between several SD cards (2-16GB), wires set and SD socket breakout boards without any success...
The only change in the example code I did is setting CS to pin 19 (though I also tried to leave it 22) when using Sparkfun's micro SD shield.
I've single stepped through the code to the lowest level: disk_initialize(0) @main.c >> nrf_blk_dev_init() @nrf_block_dev.h >> block_dev_sdc_init() @nrf_block_dev_sdc.c  >> app_sdc_init() @app_sdcard.c >> which calls nrf_drv_spi_transfer() with CS_DEASSERTed to generate 80 SCLK pulses (as the comment in the code says)
I've set a breakpoint in the callback sdc_handler() @nrf_block_dev_sdc.c and noticed that event->result = 0x04 SDC_ERROR_COMMUNICATION (in case SDC_EVT_INIT: block)
What can cause this initialization failure?
Thanks
