Four layer PCB stack up for NRF51822. RF antenna trace width.
Hi
I am developing 4 layer PCB for the nRF51822 with a power and a ground plane in the inner layers. I will be using a balun from Johanson Technology (2450BM14E0003) with the Johanson Technology (2450AT18A100)chip antenna.
PCB thickness will be 63 mils.
Please help to solve below queries:
1. The product specification of the nRF51822 says that I need to put a keep-out area under the antenna matching circuitry. Is this keep-out also needed when using a balun? Or can I both have a power and a ground layer there?
2. Stack up considered.
    Top layer ( Antenna RF trace )
    Gnd layer
    Power layer
    Bottom layer
50 ohm impedance matching should be coplanar waveguide right?
3. What trace width should i consider in top layer for 50 ohm RF Antenna trace from Balun to Chip antenna.
4. What reference layer should be consider for RF antenna trace, gnd layer or power layer?
5. what should be seperation of gnd plane from RF trace on same top layer? twice of tracewidth or thrice of trace width?
6. If possible share stack of four layer with 63 mils of pcb thickness.
