Delete all but recent peers when PM_EVT_STORAGE_FULL event happens
I'm using nRF52832 with IAR and SDK V15, S132.
I incorporated the peer manager in the uart serial profile example.
I assume, since I have 3 pages (inc. GC) set in FDS, that the Device and Central can store about 50 bonded peers.
As far as I understand, once a new bond request is received and there's no more space left I will get the PM_EVT_STORAGE_FULL event.
Currently, in that event the following code is implemented:
          err_code = fds_gc();
          if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
This makes no sense as the FDS is used only for bonded device information, so I assume I must delete the peers before running the fds_gc() function.
I read that the peers cannot be deleted when the device is connectable or connected, so is it safe to delete the peers in this event?
Also, is it safe to delete the peers in the PM_EVT_CONN_SEC_FAILED event?
Please answer the above regarding both Central and Peripheral.
The function pm_peers_delete() deletes all peers, how can I modify it to delete only the oldest peers? say, half of the stored peers?
Thank you
  • so I assume I must delete the peers before running the fds_gc() function
    Your assumtion is wrong. Please re-read the chapter on how fds works: It keeps stale data next to "current" data records. This could exaust your flash pages, even when most of the space in each page is "stale".
    The fds_gc() function copies the "current" records into new page(s) - thus compacting the data.
    Probably not, because an attacker can now force you to delete your bonding. But we know nothing about your application...
    The peer manager has a ranking function that one could use in order to determine the newst/oldest peer for deletion.
  • Your assumtion is wrong. Please re-read the chapter on how fds works: It keeps stale data next to "current" data records. This could exaust your flash pages, even when most of the space in each page is "stale".
    According to here:
    "FDS relies on garbage collection to reclaim flash space used by records that have been invalidated....... if there are any dirty records in flash which can be garbage collected."
    As far as I understand previously bonded devices information is not invalidated and not "dirty" so why will the garbage collector reclaim this space?
    And as response to question #2 here:
    "You can check whether there are deleted records in flash, using fds_stat() for instance. If fds_gc() does not free enough space, then the record cannot fit in flash: the flash is full. You have to delete something and run GC."
    So, please explain to me, how in the event of PM_EVT_STORAGE_FULL simply running the fds_gc() without deleting old peers data will the system have space to new bond?
    My question wasn't about security, but if it is safe regarding the requirement not to erase during connectable/connected state.
    Can you explain how that works?
  • I am sure there will be different answer depending on who you ask, but I would only execute delete peer(s) between connections.
    There is support for a rank system in the peer manager module, such that each time you re-connect with previous bonded peer you may set it as the highest rank (call pm_peer_rank_highest()), thereby the oldest used peer will have the lowest rank (call pm_peer_ranks_get()). You can count number of available peers between connections by calling pm_peer_count(), thereby if you want to support 50 peers, then set the max to 51, and delete the oldest peer when pm_peer_count() return 51. A peer is deleted by calling pm_peer_delete() and you may run garbage collection.
    Alternatively to use the built-in rank system you may also iterate through peers and retrieve your own application data by something similar to:
        // Example on how to read stored peer ids and stored application data
        NRF_LOG_INFO("Show stored peer id and your application data");
        uint16_t stored_length = 4;
        uint8_t stored_data[4];
        pm_peer_id_t peer_id;
        peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
        while ((peer_id != PM_PEER_ID_INVALID))
            err_code = pm_peer_data_app_data_load(peer_id, stored_data, &stored_length); // This can be data you load from the bond.
            if(err_code == NRF_SUCCESS)
                NRF_LOG_INFO("Peer id: %d Your stored application data: %d", peer_id, stored_data[0]);
                NRF_LOG_INFO("No hit");
            peer_id = pm_next_peer_id_get(peer_id);
    To store some application specific data to a peer (e.g. on PM_EVT_PEER_DATA_UPDATE_SUCCEEDED):
                    // Example on how to store data to a peer id
                    __align(4) static uint8_t stored_data[4];
                    stored_data[0] = m_button; // As an example a button press
                    err_code = pm_peer_data_app_data_store(m_peer_id, &stored_data, stored_length, NULL);
    This will allow you to store and load any generic application data as you see fit to a bond, for instance you can make your own implementation of a rank system and/or store other application related data.
    Kenneth
  • But am I right in my assumption that I must delete peers in order for the garbage collector to have any effect?
    And if I get PM_EVT_CONN_SEC_FAILED or PM_EVT_STORAGE_FULL event, is it safe to assume I'm not connected nor advertising?
     Not necessarily, there may also be other flash operations occurring, for instance if you are using the rank system.
    No. You will need to monitor disconnect event, delete, and then start advertising/scan.
    Kenneth
