Hello!
Hello, I have an Issue with NRF51822 chip, made an over 25k messages per second transmitter based on Keil example, but the main difference is that I dont enbable and disable radio each time I transmit information, but do it only once in the begining. After 60 seconds (sometimes more) receiver stops getting messages, but check-pin toggles on transmitter (see code), if I reset transmitter, receiver starts getting messages again. I handled it with disabling and enabling radio on transmitter once in 10 seconds, but I suppose it is not the best way to solve it. I'd like to know what could go wrong? Do I really have to re-ramp up radio for the correcnt perfomance?
Here is main function and radio configurations:
int main()
//set clock
clock_initialization();
// Set radio configuration parameters
radio_configure();
// Set payload pointer
NRF_RADIO->PACKETPTR = (uint32_t)&packet;
//ramp up
NRF_RADIO->EVENTS_READY = 0U;
NRF_RADIO->TASKS_TXEN = 1;
while (NRF_RADIO->EVENTS_READY == 0U);
/* some initialization of other perepherial */
while (1)
/* wait for some event */
//sending packet
NRF_RADIO->EVENTS_END = 0U;
NRF_RADIO->TASKS_START = 1U;
while (NRF_RADIO->EVENTS_END == 0U);
/* toggling pin to make sure events_end */
void radio_configure()
// Radio config
NRF_RADIO->TXPOWER = (RADIO_TXPOWER_TXPOWER_Pos4dBm << RADIO_TXPOWER_TXPOWER_Pos);
NRF_RADIO->FREQUENCY = 75UL;
NRF_RADIO->MODE = (RADIO_MODE_MODE_Nrf_2Mbit << RADIO_MODE_MODE_Pos);
// Radio address config
NRF_RADIO->PREFIX0 =
((uint32_t)swap_bits(0xC3) << 24) // Prefix byte of address 3 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC2) << 16) // Prefix byte of address 2 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC1) << 8) // Prefix byte of address 1 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC0) << 0); // Prefix byte of address 0 converted to nRF24L series format
NRF_RADIO->PREFIX1 =
((uint32_t)swap_bits(0xC7) << 24) // Prefix byte of address 7 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC6) << 16) // Prefix byte of address 6 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC4) << 0); // Prefix byte of address 4 converted to nRF24L series format
NRF_RADIO->BASE0 = bytewise_bitswap(0x01234567UL); // Base address for prefix 0 converted to nRF24L series format
NRF_RADIO->BASE1 = bytewise_bitswap(0x89ABCDEFUL); // Base address for prefix 1-7 converted to nRF24L series format
NRF_RADIO->TXADDRESS = 0x00UL; // Set device address 0 to use when transmitting
NRF_RADIO->RXADDRESSES = 0x01UL; // Enable device address 0 to use to select which addresses to receive
// Packet configuration
NRF_RADIO->PCNF0 = (PACKET_S1_FIELD_SIZE << RADIO_PCNF0_S1LEN_Pos) |
(PACKET_S0_FIELD_SIZE << RADIO_PCNF0_S0LEN_Pos) |
(PACKET_LENGTH_FIELD_SIZE << RADIO_PCNF0_LFLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
NRF_RADIO->PCNF1 = (RADIO_PCNF1_WHITEEN_Disabled << RADIO_PCNF1_WHITEEN_Pos) |
(RADIO_PCNF1_ENDIAN_Big << RADIO_PCNF1_ENDIAN_Pos) |
(PACKET_BASE_ADDRESS_LENGTH << RADIO_PCNF1_BALEN_Pos) |
(PACKET_STATIC_LENGTH << RADIO_PCNF1_STATLEN_Pos) |
(PACKET_PAYLOAD_MAXSIZE << RADIO_PCNF1_MAXLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
// CRC Config
NRF_RADIO->CRCCNF = (RADIO_CRCCNF_LEN_Disabled << RADIO_CRCCNF_LEN_Pos); // Number of checksum bits
if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x11021UL; // CRC poly: x^16+x^12^x^5+1
else if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_One << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x107UL; // CRC poly: x^8+x^2^x^1+1
}#ifndef RADIO_CONFIG_H #define RADIO_CONFIG_H #define PACKET_BASE_ADDRESS_LENGTH (1UL) #define PACKET_STATIC_LENGTH (0UL) #define PACKET_PAYLOAD_MAXSIZE (PACKET_STATIC_LENGTH) //!< Packet payload maximum size in bytes void radio_configure(void); #endif
