How can I use micros() with systick or Timer in nRF51822/ ble_app_beacon example
To do some test, I need micros(). This is the reason why I couldn't use RTC or app_timer.
When I tried timer example(nRF5_SDK_12.2.0_f012efa\examples\peripheral\), I could use micros well.
However, it didn't work on ble_app_beacon example even referenced this. When I start debug mode on keil5, the stop point is "hardfalut handler".
is there example code about it? and is there any way to use systick?
am I missing something important things?
== condition ==
- nRF51822
- SDK12.2.0
- ble_app_beacon example
- Using NRF_LOG
    Can you check whether nrf_drv_timer_init() returns 0 or something else?
    I suspect that the hardfault is caused by the fact that you use const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(0); which is already in use by the softdevice.
    Can you try to change this to NRF_DRV_TIMER_INSTANCE(1); Remember to enable TIMER1 in sdk_config.h (#define TIMER1_ENABLED 1).
    Edvin
