I tried to send data through the proprietary radio. My devices are NRF52832. The data I would like to send is an uint8_t array:
uint8_t radioTxBuffer[10]; // and radioTxBuffer[0] = 6; radioTxBuffer[1] = 11; radioTxBuffer[2] = 2; radioTxBuffer[3] = 2; radioTxBuffer[4] = 2; radioTxBuffer[5] = 2; radioTxBuffer[6] = 2; radioTxBuffer[7] = 2; radioTxBuffer[8] = 2; radioTxBuffer[9] = 2;
Right before I send it out, I copied it to another variable, then print it (on the next cycle, to ensure printing won't affect everything).
This is the output I received from the transmitter:
copied[0]: 6 copied[1]: 11 copied[2]: 2 copied[3]: 2 copied[4]: 2 copied[5]: 2 copied[6]: 2 copied[7]: 2 copied[8]: 2 copied[9]: 2
Otherwise, the data received is a little bit different - the last 3 items of the array are 0
Here's the output:
copied[0]: 6 copied[1]: 11 copied[2]: 2 copied[3]: 2 copied[4]: 2 copied[5]: 2 copied[6]: 2 copied[7]: 0 copied[8]: 0 copied[9]: 0
I also made a sniffer (which I believe works perfectly fine), and its output looks like:
<info> app: Packet was received <info> app: The contents of the package is 6 <info> app: The contents of the package is B <info> app: The contents of the package is 2 <info> app: The contents of the package is 2 <info> app: The contents of the package is 2 <info> app: The contents of the package is 2 <info> app: The contents of the package is 2 <info> app: The contents of the package is 0 <info> app: The contents of the package is 0 <info> app: The contents of the package is 0
*p.s: nevermind about the B, I used %x there.
I followed the example of Radio -> Transmitter and Radio -> Receiver as a reference for my code. I tried to edit it and it works fine as I expected (change the packet buffer to an uint8_t 10-elements array)
Any suggestion on this?
Thanks in advance
