NRF_LOG_INFO duplicate output in Debug Terminal
In trying to debug I2C usage of BNO055 device, I've sprinkled NRF_LOG_INFO around in my code.
This is Very simple stuff, yet I am seeing erratic behavior of the logging.  In this code snippet:
result = imu_init();
nrf_delay_ms(1000);
NRF_LOG_INFO("AAAAAAAA");
u8 chip_id_u8;
s8 errval = bno055_read_chip_id(&chip_id_u8);
// nrf_delay_ms(100);
NRF_LOG_INFO("errval = %d, chipid = %d, ctr=%d", errval, chip_id_u8, ctr++);
NRF_LOG_INFO("BBBBBBBBBB");
nrf_delay_ms(100);
NRF_LOG_INFO("CCCCCCCCCC");
====> The code above appears in my main() function, prior to a loop on idle_state_handle();
The output I see is:
1 <info> app: AAAAAAAA
2 <info> app: BNO055_I2C_bus_read err = 0 (from bno055_read_chip_id call)
3 <info> app: errval = 0, chipid = 0, ctr=0
4 <info> app: Temperature: 0 Celsius degrees. (from lower-level code)
5 <info> app: errval = 0, chipid = 0, ctr=0     <===== NOTE THE DUPLICATE OUTPUT
6 <info> app: Temperature: 0 Celsius degrees.
7 <info> app: BBBBBBBBBB
8 <info> app: CCCCCCCCCC
So, I thought perhaps slowing things down a bit might be helpful.  Adding delay right after
the bno055_read_chip_id call results in output of Only lines 1-4.
FWIW, I changed the SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN from 16 to 256;
no effect.  Anyone have any idea what I might be doing wrong here?
Thanks!
  • Hi Jim,
    Sorry for the late reply, half the office here was busy with Electronica conference last week. I haven't seen this error before, are you sure you are not printing the same log info from two different places in your code? Could you send me the sdk_config.h file so I can take a look at how the logging module is configured?
    Best Regards,
    Marjeris
  • Hi!  Thanks for getting back!  I'm still baffled by this one!
    I've attached sdk_config.h and my main.c.  Putting breakpoints on the logging calls
    shows me that they are only getting executed once; but the output disagrees!
    I really appreciate any insights you might have!
    Jim1616.sdk_config.h
    BLE_SF_Breakout_Blinky
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <ctype.h>
    #include <string.h>
    #include <nrfx.h>
    #include "nordic_common.h"
    #include "nrfx_twi.h"
    #include "nrf_gpio.h"
    #include "nrf.h"
    #include "config.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "customboards.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "bno055.h"
    #include "BNO055_I2C.h"
    #include "nrf_log.h"
    #include "nrf_delay.h"
    #include "nrf_log_ctrl.h"
    #define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
    #define CONNECTED_LED                   BSP_BOARD_LED_0                         /**< Is on when device has connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_0                         /**< LED to be toggled with the help of the LED Button Service. */
    #define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
    #define DEVICE_NAME                     "SF_BLE_Blinky"                         /**< Name of device. Will be included in the advertising data. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
    static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
    /* Indicates if operation on TWI has ended. */
    static volatile bool m_xfer_done = false;
    /* Buffer for samples read from temperature sensor. */
    static uint8_t m_sample;
    struct bno055_t bno055;
    static s32 result;
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = m_enc_scan_response_data,
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
        ret_code_t              err_code;
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_advdata_t advdata;
        ble_advdata_t srdata;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
        ble_gap_adv_params_t adv_params;
        // Set advertising parameters.
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
        adv_params.duration        = APP_ADV_DURATION;
        adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        adv_params.p_peer_addr     = NULL;
        adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        adv_params.interval        = APP_ADV_INTERVAL;
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
        APP_ERROR_HANDLER(nrf_error);
     static bool togglestate = false;
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            bsp_board_led_on(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED ON!");
            bsp_board_led_off(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED OFF!");
        togglestate = led_state;
        if (togglestate)
          nrf_gpio_pin_set(14);
          nrf_gpio_pin_clear(17);
          nrf_gpio_pin_set(17);
          nrf_gpio_pin_clear(14);
     //   togglestate ^= true;
        ble_lbs_init_t     init     = {0};
        // Initialize LBS.
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        bsp_board_led_on(ADVERTISING_LED);
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                bsp_board_led_on(CONNECTED_LED);
                bsp_board_led_off(ADVERTISING_LED);
                err_code = app_button_enable();
                NRF_LOG_INFO("Disconnected");
                bsp_board_led_off(CONNECTED_LED);
                err_code = app_button_disable();
                advertising_start();
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON:
                NRF_LOG_INFO("Send button state change.");
                err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE &&
                    err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    ============== TWI methods ===========================
    // TWIM0 - I2C channel 1
    static nrfx_twi_t m_twi_master = NRFX_TWI_INSTANCE(MASTER_TWI_INST);
     * @brief Function for handling data from temperature sensor.
     * @param[in] temp          Temperature in Celsius degrees read from sensor.
    __STATIC_INLINE void data_handler(uint8_t temp)
        NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
     * @brief TWI events handler.
    void twi_handler(nrfx_twi_evt_t const * p_event, void * p_context)
        switch (p_event->type)
            case NRFX_TWI_EVT_DONE:
                if (p_event->xfer_desc.type == NRFX_TWI_XFER_RX)
                    data_handler(m_sample);
                m_xfer_done = true;
    static ret_code_t twi_master_init(void)
        ret_code_t ret;
        const nrfx_twi_config_t config =
           .scl                = TWI_SCL_M,
           .sda                = TWI_SDA_M,
           .frequency          = NRF_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .hold_bus_uninit      = true
        ret = nrfx_twi_init(&m_twi_master, &config, twi_handler, NULL);
        if (NRF_SUCCESS == ret)
            nrfx_twi_enable(&m_twi_master);
        return ret;
    // ====================== BNO055 methods =====================================
    s8 imu_init(void)
      return BNO055_I2C_Init(&m_twi_master);
    /**@brief Function for application main entry.
    static u8 ctr = 0;
        s8 result = BNO055_INIT_VALUE;
        // Initialize.
        log_init();
        leds_init();
        timers_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        nrf_gpio_cfg_output(14);
    //    nrf_gpio_cfg_output(15);
    //    nrf_gpio_cfg_output(16);
        nrf_gpio_cfg_output(17);
        // P18 is the Cortex clock
        // Start execution.
        NRF_LOG_INFO("Starting!");
    //    advertising_start();
        twi_master_init();
        nrf_delay_ms(1000);
        nrf_delay_ms(1000);
        u8 chip_id_u8;
        s8 errval;
    // NOTE: ADDING THE FOLLOWING CALL RESULTS IN no subsequent output!
        nrf_delay_ms(100);
        nrf_delay_ms(100);
     //   nrf_delay_ms(1000);
    //    s8 temp_data;
    //    s8 retval = bno055_read_temp_data(&temp_data);
    //    NRF_LOG_INFO("retval = %d, temp = %d, ctr=%d", retval, temp_data, ctr++);
        // Enter main loop.
        for (;;)
           if ( true) //NRF_LOG_PROCESS() == false)
  • Hi Jim,
    I don't know what can be causing this behaviour. I took your main and sdk file, made my own declarations for errval, chip_id_u8 and ctr and didn't see any duplicates in the RTT debug viewer of SES. So my thoughts are that the problem must come from the function bno055_read_chip_id. Maybe you can test doing the same as well?
    //    u8 chip_id_u8;
    //    s8 errval;
    //   errval = bno055_read_chip_id(&chip_id_u8);
         int8_t errval=0;
         uint8_t chip_id_u8=0;
         uint8_t ctr=0;
    Have you made any modifications to bno055_read_chip_id function? Are you sure you are not printing any logs inside this function?
    Best Regards,
    Marjeris
  • I had a couple of lower-level logging calls in my I2C code (called by bno055_read_chip_id).  Removing them changed the behavior of the top-level logging in main:  no more duplicate "BBBBBB", but no "CCCCCC" output after that.  Removing the call to bno055_read_chip_id (note there are no longer lower-level logging calls anywhere) causes all main.c logging to appear correctly.  BUT (this is where it gets more weird!) keeping the call to bno055_read_chip_id and removing the delay call between "BBBBB" and "CCCC" logging calls, results in duplicate "CCCCCC" output!
    My suspicion is that there is something going goofy with logging buffering/flushing mechanism, but I don't have deep familiarity with the underlying code there.   If it was just a case of duplicate output showing up, I might be able to consider that "benign" and ignore it; but when output goes missing.... well, that's not good.   Is there any other info I can provide that might be helpful here?
    Thanks very much!
    Jim
  • Hi Jim,
    Maybe the RTT buffer is full? Can you try to implement the solution in this case and see if that helps with the missing outputs?
    As explained by Sigurd, try to change the SEGGER_RTT_CONFIG_DEFAULT_MODE  and to increase the SEGGER_RTT_CONFIG_BUFFER_SIZE_UP to 1024 in sdk_config.h
    If this does not work maybe you will need to sent me your i2c files so I can try to reproduce the issue...
    Best Regards,
    Marjeris
