I am working with NRF52832 master with TWI slave device, however , since our board already has external pull-up resistors (10K) , how do I disable TWI internal pull up resistors ?
I am using SDK14.2
Thank you in advance
Ildefonso
I am using SDK14.2
Ildefonso
Hi
The internal pull-up is set in the nrf_drv_twi_init() function in the nrf_drv_twi.c file:
NRF_GPIO->PIN_CNF[p_config->scl] = SCL_PIN_INIT_CONF; NRF_GPIO->PIN_CNF[p_config->sda] = SDA_PIN_INIT_CONF;
SCL_PIN_INIT_CONF is defined as:
#define SCL_PIN_INIT_CONF ( (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos) \
| (GPIO_PIN_CNF_DRIVE_S0D1 << GPIO_PIN_CNF_DRIVE_Pos) \
| (GPIO_PIN_CNF_PULL_Pullup << GPIO_PIN_CNF_PULL_Pos) \
| (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) \
| (GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos))
Where the pull-up is set with the GPIO_PIN_CNF_PULL_Pullup with GPIO_PIN_CNF_PULL_Disabled. Replace GPIO_PIN_CNF_PULL_Pullup with GPIO_PIN_CNF_PULL_Disabled
Use the same method for changing the internal pull-up on the SDA pin,
Jared
