Hi (I'm new at this, sorry for my question) About Gazell & Pipe (nRF24LE1) What is the utility of 6 or 8 pipe, whether only has 3 RX_FIFO for working simultaneous? Can you give me an example? (That is, if only 6 frames can carry simultaneously, I can only respond immediately to 3. I do not understand how I can take this advantage.) If TX packet will be removed from the TX FIFO when a new packet is received on the same pipe.. How can I know the number of the pipes remaining into the TX_FIFO? The only solution for this answer pass for my payload or there is other way. Thank you Matias
