Restart the advertising
Dear Sir,
I want to do the following scenario.
Once I power the device it will start advertising.
Now the advertising duration is 2minutes.
I have written a routine based on timer. When it is called it should initiate the advertising again.
How can I  restart an advertising sequence once a current advertising going on?.
I tried the following sequence
(void) sd_ble_gap_adv_stop(&m_advertising.adv_handle);
advertising_start(erase_bonds);
But it shows the error
 WakeUp
<error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at I:\GK\Rigado\sdk\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\Sieva_prod1_wologs\main.c:1325
What am I missing in restarting advertising routine?
In function "ble_advertising_restart_without_whitelist()", I think it follows the same sequence.
But I dont know why it is not working for me.
Please shed some light on this.
with regards,
Geetha
  • Hi ,
    Suppose if we use ble_advertising_start() to start the advertising.
    Can I use sd_ble_gap_adv_stop(). to stop the current instance of advertising?
    If yes, what should be the steps to be taken?
    Can I use sd_ble_gap_adv_start() to restrat the advertising again after stopping one instance of advertising?
    PLease share your ideas on the same.
    with regards,
    Geetha
  • Hi.
    I've been out of office this week.
    Yes, you can use sd_ble_gap_adv_stop() to stop the current instance of advertising, just call it and use your advertising handle as input in the function.
    And yes, you can start it again by using sd_ble_gap_adv_start(), just call it and use your advertising hnadle as a input in the function.
    - Andreas
  • if I write this
    //Stop
    err_code = sd_ble_gap_adv_stop(m_adv_handle);
    NRF_LOG_INFO("Stopping advertising");
    //Start
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    NRF_LOG_INFO("Starting advertising");
    Then I am getting these errors:
    ./../../main.c: In function 'nus_data_handler':
    ../../../main.c:205:32: error: 'm_adv_handle' undeclared (first use in this function); did you mean 'm_conn_handle'?
    m_conn_handle
    ../../../main.c:205:32: note: each undeclared identifier is reported only once for each function it appears in
    ../../../main.c:205:12: error: too many arguments to function 'sd_ble_gap_adv_stop'
    In file included from ../../../../../../components/softdevice/s132/headers/ble_gap.h:49,
    from ../../../../../../components/softdevice/s132/headers/ble.h:52,
    from ../../../../../../components/ble/common/ble_advdata.h:55,
    from ../../../main.c:56:
    ../../../../../../components/softdevice/s132/headers/ble_gap.h:1448:39: note: declared here
    SVCALL(SD_BLE_GAP_ADV_STOP, uint32_t, sd_ble_gap_adv_stop(void));
    ../../../../../../components/softdevice/s132/headers/nrf_svc.h:64:22: note: in definition of macro 'SVCALL'
    static return_type signature \
    ../../../main.c:210:47: error: 'APP_BLE_CONN_CFG_TAG' undeclared (first use in this function); did you mean 'BLE_CONN_CFG_GAP'?
  • Hi
    It seems like you are having quite a few undeclared identifiers in your applications. Please make sure these are declared in your project and try again.
    This ticket is over 1 year old, so if you're having trouble with this, I suggest creating a new ticket describing your issue in detail.
    Simon
