Restart the advertising
Dear Sir,
I want to do the following scenario.
Once I power the device it will start advertising.
Now the advertising duration is 2minutes.
I have written a routine based on timer. When it is called it should initiate the advertising again.
How can I  restart an advertising sequence once a current advertising going on?.
I tried the following sequence
(void) sd_ble_gap_adv_stop(&m_advertising.adv_handle);
advertising_start(erase_bonds);
But it shows the error
 WakeUp
<error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at I:\GK\Rigado\sdk\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\Sieva_prod1_wologs\main.c:1325
What am I missing in restarting advertising routine?
In function "ble_advertising_restart_without_whitelist()", I think it follows the same sequence.
But I dont know why it is not working for me.
Please shed some light on this.
with regards,
Geetha
  • Hi.
    The error code is most likely because when you try to stop advertising, you're not advertising. Look at this question for more information about NRF_ERROR_INVALID_STATE and advertising.
    The proper way to start/stop would be:
    //Stop
    err_code = sd_ble_gap_adv_stop(m_adv_handle);
    NRF_LOG_INFO("Stopping advertising");
    //Start
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    NRF_LOG_INFO("Starting advertising");
    Look at this question, there is an attached .zip file containing a modified beacon example, where start/stop advertising is implemented as a handle of pressing button 1 (in void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action))
    - Andreas
    Thank you very much for your response.
    My scenario is as follows.
    I am using 2 timers.
    First timer will wake up for each 5 mins and second one wake up after the first 1 minute.
    So when I start the device , it advertises. And initial 1 minute I will do a connect-disconnect method to get the adddresses.
    Now once I disconnect the device it will start advertising since the function "ble_advertising_start()"  is getting called inside "on_disconnected()" function.
    If I want to stop advertising from the main.c file  how can I do this?..
    how can I get the advertising handle?
    Which function I should call from the main function to stop the current advertising instance and to start a new one?
    I tried your scenario, but it shows the same problem
    Thanking you
  • Hi.
    Did you look at this? It's pretty straight forward shown how to use the two API's I posted in my previous reply.
    The handle is initialized in the top of main.c
    static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
    And the pin handler starts and stops advertising.
        ret_code_t err_code;
        nrf_drv_gpiote_out_toggle(PIN_OUT);
        if(is_advertising){
            is_advertising = false;
        } else{
            is_advertising = true;
    You have probably defined &m_advertising as your advertising handle.
    - Andreas
  • Hi Andeas,
    Thank you very much for your reply.
    That means I am not supposed to use the function "ble_advertising_start()" to start advertising?
     And instead of that should I use "sd_ble_gap_adv_start()" directly?
    Inside this function  "ble_advertising_start()"   it uses "sd_ble_gap_adv_start()" and some more things extra.
    Please shed some light.
  • Hi.
    ble_advertising_start() is an API call to start advertising using the Advertising Module. At the bottom of the module, advertising is started by sd_ble_gap_adv_start() (line 657 in ble_advertising.c) If you don't need to do some of the "extra things" you refer to before you start advertising, you don't need to use ble_advertising_start().
    If you only need to start or stop advertising you can safely use only sd_ble_gap_adv_start() and sd_ble_gap_adv_stop().
    - Andreas
