Hi everyone,
I'm having an issue with the power draw of my application (SDK 15.0.0, SD 132 v6, Sparkfun nRF52832 Breakout). The application does roughly the following: it sleeps until it receives an GPIO interrupt (there are two different GPIOs which can wake up the application), does some (non connectable) advertising and resumes sleeping.
According to the data sheet of the nRF52832 0.7 µA are possible with full RAM retention and in system state System OFF. The power draw of my application exceeds this number (around ten times higher), however I'm not utilising the System OFF mode yet (currently using only the nrf_pwr_mgmt_run() function).
I did some research and discovered the sd_power_off() function. When I add the sd_power_off() function to my code, the system "freezes" / 'hangs" and draws about 10mA.
I did take a look at the example "ble_app_pwr_profiling" but it is rather complex - has anyone created / found a simpler solution (do some advertising, go to System OFF with RAM retention, wake up to an GPIO interrupt, repeat) yet?
How can I differentiate the two different GPIO interrupt sources when using them to wake up? (I want to count the times my application has woken up to sources 1 and 2)
Best,
lhochstetter
