Minimizing the power draw using System OFF and RAM retention
Hi everyone,
I'm having an issue with the power draw of my application (SDK 15.0.0, SD 132 v6, Sparkfun nRF52832 Breakout). The application does roughly the following: it sleeps until it receives an GPIO interrupt (there are two different GPIOs which can wake up the application), does some (non connectable) advertising and resumes sleeping.
According to the data sheet of the nRF52832 0.7 µA are possible with full RAM retention and in system state System OFF. The power draw of my application exceeds this number (around ten times higher), however I'm not utilising the System OFF mode yet (currently using only the nrf_pwr_mgmt_run() function).
I did some research and discovered the sd_power_off() function. When I add the sd_power_off() function to my code, the system "freezes" / 'hangs" and draws about 10mA.
I did take a look at the example "ble_app_pwr_profiling" but it is rather complex - has anyone created / found a simpler solution (do some advertising, go to System OFF with RAM retention, wake up to an GPIO interrupt, repeat) yet?
How can I differentiate the two different GPIO interrupt sources when using them to wake up? (I want to count the times my application has woken up to sources 1 and 2)
Best,
lhochstetter
    thanks for the link, I tried to merge your example (the gcc one) with mine, but sadly it didn't work out i.e. the value was not retained. Again I'm trying to only save the second slave of the 7th RAM tile.
    Code snippets:
    uint32_t j __attribute__((section(".no_init"))) __attribute__((used));
    	// Initialize.
    	gpio_init();
    	ble_stack_init();
    	sd_power_ram_power_set(7, (POWER_RAM_POWER_S1POWER_On << POWER_RAM_POWER_S1POWER_Pos)
    		                | (POWER_RAM_POWER_S1RETENTION_On << POWER_RAM_POWER_S1RETENTION_Pos));
    	if (0 == nrf_gpio_pin_read(BSP_BUTTON_0)) {
    		nrf_drv_gpiote_out_clear(BSP_LED_0);
    	if (3 == j) {
    		nrf_drv_gpiote_out_clear(BSP_LED_2);
    		j = 0;
    	j++;
    	nrf_delay_ms(1000);
    	nrf_drv_gpiote_out_set(BSP_LED_0);
    	nrf_drv_gpiote_out_set(BSP_LED_2);
    	sd_power_system_off();
    	for(;;) {
    		idle_state_handle();
    My linker file (based on the original ble_app_beacon) which I tied to merge with the linker file provided in your example.
    /* Linker script to configure memory regions. */
    SEARCH_DIR(.)
    GROUP(-lgcc -lc -lnosys)
    MEMORY
      FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0x5a000
      RAM (rwx) :  ORIGIN = 0x200018a8, LENGTH = 0xd758
      NO_INIT (rwx) :  ORIGIN = 0x2000F000, LENGTH = 0x1000
    SECTIONS
      .no_init (NOLOAD):
        PROVIDE(__start_no_init_data = .);
    	KEEP(*(SORT(.no_init*)))
    	PROVIDE(__stop_no_init_data = .);
      } > NO_INIT
    SECTIONS
      . = ALIGN(4);
      .mem_section_dummy_ram :
      .log_dynamic_data :
        PROVIDE(__start_log_dynamic_data = .);
        KEEP(*(SORT(.log_dynamic_data*)))
        PROVIDE(__stop_log_dynamic_data = .);
      } > RAM
      .cli_sorted_cmd_ptrs :
        PROVIDE(__start_cli_sorted_cmd_ptrs = .);
        KEEP(*(.cli_sorted_cmd_ptrs))
        PROVIDE(__stop_cli_sorted_cmd_ptrs = .);
      } > RAM
      .fs_data :
        PROVIDE(__start_fs_data = .);
        KEEP(*(.fs_data))
        PROVIDE(__stop_fs_data = .);
      } > RAM
    } INSERT AFTER .data;
    SECTIONS
      .mem_section_dummy_rom :
      .sdh_soc_observers :
        PROVIDE(__start_sdh_soc_observers = .);
        KEEP(*(SORT(.sdh_soc_observers*)))
        PROVIDE(__stop_sdh_soc_observers = .);
      } > FLASH
      .sdh_ble_observers :
        PROVIDE(__start_sdh_ble_observers = .);
        KEEP(*(SORT(.sdh_ble_observers*)))
        PROVIDE(__stop_sdh_ble_observers = .);
      } > FLASH
      .pwr_mgmt_data :
        PROVIDE(__start_pwr_mgmt_data = .);
        KEEP(*(SORT(.pwr_mgmt_data*)))
        PROVIDE(__stop_pwr_mgmt_data = .);
      } > FLASH
      .log_const_data :
        PROVIDE(__start_log_const_data = .);
        KEEP(*(SORT(.log_const_data*)))
        PROVIDE(__stop_log_const_data = .);
      } > FLASH
        .nrf_balloc :
        PROVIDE(__start_nrf_balloc = .);
        KEEP(*(.nrf_balloc))
        PROVIDE(__stop_nrf_balloc = .);
      } > FLASH
      .sdh_state_observers :
        PROVIDE(__start_sdh_state_observers = .);
        KEEP(*(SORT(.sdh_state_observers*)))
        PROVIDE(__stop_sdh_state_observers = .);
      } > FLASH
      .sdh_stack_observers :
        PROVIDE(__start_sdh_stack_observers = .);
        KEEP(*(SORT(.sdh_stack_observers*)))
        PROVIDE(__stop_sdh_stack_observers = .);
      } > FLASH
      .sdh_req_observers :
        PROVIDE(__start_sdh_req_observers = .);
        KEEP(*(SORT(.sdh_req_observers*)))
        PROVIDE(__stop_sdh_req_observers = .);
      } > FLASH
        .nrf_queue :
        PROVIDE(__start_nrf_queue = .);
        KEEP(*(.nrf_queue))
        PROVIDE(__stop_nrf_queue = .);
      } > FLASH
        .cli_command :
        PROVIDE(__start_cli_command = .);
        KEEP(*(.cli_command))
        PROVIDE(__stop_cli_command = .);
      } > FLASH
      .crypto_data :
        PROVIDE(__start_crypto_data = .);
        KEEP(*(SORT(.crypto_data*)))
        PROVIDE(__stop_crypto_data = .);
      } > FLASH
    } INSERT AFTER .text
    INCLUDE "nrf_common.ld"
    Sorry for making you basically hold my hand but I'm fairly ignorant when it comes to the SDK and how things work / are compiled ... is there by chance an introduction / tutorial which explains the SDK structure etc. ? (I'm also at a loss when it comes to tracking down function definitions etc.)
    I tried to compile your example but it kept complaining, that some files where missing - the ../../config directory does not seem to be in the .zip. I'm also guessing that your example was written with an older SDK version as system_nrf52.c seems to have changed places.
    lhochstetter
  • The nRF52840 board has integrated Segger J-Link debugger which is accessible via USB. The J-Link in turn talks to the 52840 chip via its Serial Wire Debug (SWD) pins. SWD is an ARM standard debug interface present on Cortex-M chips. This is how you flash the board, you can also use it to take control of the 52840 CPU and dump its memory, control its execution of code. You can use OpenOCD to connect to the J-Link interface and then use gdb to set breakpoints and single step the CPU one line or one instruction at a time, e.g.:
    (gdb) target remote localhost:3333 # connect to OpenOCD running on local machine
    (gdb) monitor reset init # reset CPU
    (gdb) break main          # set breakpoint at main()
    (gdb) continue             # let the CPU run
    <target continues, until it hits main>
    (gdb) step                   # step one line
    (gdb) stepi                  # step one instruction
    (gdb) info registers     # examine machine state
    (etc...)
    It sounds like system off mode won't work as long as the SWD interface on the CPU is in use, which means you have to let the CPU run without GDB connected in order to test it.
  • Hi wpaul,
    Do you mean I connect to OpenOCD for debugging? Actually my problem is to find out how to get the current draw from the nrf52832 to be 0.7uA when it is in SYSTEM OFF. But I can only get 1.7uA when I flash the code above into it.
    Thank you very much!
    I integrated the previous example into ble_app_beacon (quick and dirty, my apologies), here's the main file and linker file (SDK v15.2):
    ble_app_beacon_gcc_nrf52.ld
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_beacon_main main.c
     * @ingroup ble_sdk_app_beacon
     * @brief Beacon Transmitter Sample Application main file.
     * This file contains the source code for an Beacon transmitter sample application.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nordic_common.h"
    #include "bsp.h"
    #include "nrf_soc.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "ble_advdata.h"
    #include "app_timer.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                  /**< A tag identifying the SoftDevice BLE configuration. */
    #define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
    #define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
    #define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
    #define APP_DEVICE_TYPE                 0x02                               /**< 0x02 refers to Beacon. */
    #define APP_MEASURED_RSSI               0xC3                               /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
    #define APP_COMPANY_IDENTIFIER          0x0059                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    #define APP_MAJOR_VALUE                 0x01, 0x02                         /**< Major value used to identify Beacons. */
    #define APP_MINOR_VALUE                 0x03, 0x04                         /**< Minor value used to identify Beacons. */
    #define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                            0x45, 0x56, 0x67, 0x78, \
                                            0x89, 0x9a, 0xab, 0xbc, \
                                            0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
    #define DEAD_BEEF                       0xDEADBEEF                         /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
    #define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                 /**< Position of the MSB of the Major Value in m_beacon_info array. */
    #define UICR_ADDRESS                    0x10001080                         /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
    static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
    static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
    static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
    static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
        APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                             // implementation.
        APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                             // manufacturer specific data in this implementation.
        APP_BEACON_UUID,     // 128 bit UUID value.
        APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
        APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
        APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                             // this implementation.
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in]   line_num   Line number of the failing ASSERT call.
     * @param[in]   file_name  File name of the failing ASSERT call.
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        uint32_t      err_code;
        ble_advdata_t advdata;
        uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
        ble_advdata_manuf_data_t manuf_specific_data;
        manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
        // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
        // UICR instead of using the default values. The major and minor values obtained from the UICR
        // are encoded into advertising data in big endian order (MSB First).
        // To set the UICR used by this example to a desired value, write to the address 0x10001080
        // using the nrfjprog tool. The command to be used is as follows.
        // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
        // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
        // the following command should be used.
        // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
        uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
        uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
        uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
        m_beacon_info[index++] = MSB_16(major_value);
        m_beacon_info[index++] = LSB_16(major_value);
        m_beacon_info[index++] = MSB_16(minor_value);
        m_beacon_info[index++] = LSB_16(minor_value);
        manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
        manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type             = BLE_ADVDATA_NO_NAME;
        advdata.flags                 = flags;
        advdata.p_manuf_specific_data = &manuf_specific_data;
        // Initialize advertising parameters (used when starting advertising).
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
        m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
        m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
        m_adv_params.duration        = 0;       // Never time out.
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
        ret_code_t err_code;
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for initializing logging. */
    static void log_init(void)
    /**@brief Function for initializing LEDs. */
    static void leds_init(void)
        ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
    /**@brief Function for initializing timers. */
    static void timers_init(void)
            nrf_pwr_mgmt_run();
    #include "nrf_delay.h"
    uint32_t test __attribute__((section(".no_init"))) __attribute__((used));
     * @brief Function for application main entry.
        // Initialize.
        log_init();
        timers_init();
        leds_init();
        power_management_init();
        /*for (int i = 0; i < 8; i++)
          NRF_POWER->RAM[i].POWER = 0xFFFFFFFF;
        ble_stack_init();
        advertising_init();
        sd_power_ram_power_set(7, (POWER_RAM_POWER_S1RETENTION_On << POWER_RAM_POWER_S1RETENTION_Pos));
        nrf_gpio_cfg_sense_input(13, NRF_GPIO_PIN_PULLUP,NRF_GPIO_PIN_SENSE_LOW);
        if (test > 0)
            uint8_t led_state = test % 4;
            nrf_gpio_pin_toggle(BSP_LED_0 + led_state);
            nrf_delay_us(100*1000);
        test++;
        // Start execution.
        NRF_LOG_INFO("Beacon example started.");
        advertising_start();
        // Enter main loop.
        for (;; )
    I didn't have any problems running this code, it loops through the LEDs like it should. Could you try this and see if that works?
    Håkon
  • Hi Håkon,
    it just works (tm)! Thank you!
    I took a closer look at your .ld and .c files and noticed some differences:
    In the .ld file you "included" the no_init declaration in the section which was to be "inserted after .text" (if I understand the .ld file correctly). I used the "spare" section at the very beginning without the "INSERT AFTER ..." command.
    I therefore suspect that my main issue was the no_init declaration at the wrong section.
    In the .c file / in the main function you "only enabled RAM retention" and did not touch the "POWER_RAM_POWER_S1POWER_On register" at all.
    One more question: could you provide me with a couple terms to research, so I can properly understand the .ld files syntax / notation?
    Thanks again!
    lhochstetter
