Hi!
Im trying to implement DFU but got stuck at sending the init packet.
The problem seems to be that the the init data doesn't get transfered somehow, and the symptom is that the CRC32 and offset returned after the transfer is 0.
Any idea how to debug this further?
The CRC should be nonzero regardless of what data I have transfered to the packet characteristic right? Or is there some validation of the init packet being done before the CRC is computed?
This is my debug log:
SelectCommand: 0
Start of init packet send
SelectCommand results CRC: 0
Received PRN set response: 60-02-01
Control point notif data: 60-01-01
Command object data: 01-01-87-00-00-00
Command object created result: 60-01-01
Start of data transfer flen: 135
Reading 20 bytes from file stream
Sent data: 12-84-01-0A-3E-08-01-12-3A-08-36-10-34-1A-02-8C-01-20-00-28
### CRC32 Step value, crc: 534647752 offset:20 size: 20 packetLocalNo:1
Sent data: 00-30-00-38-A0-C9-03-42-24-08-03-12-20-FF-B7-05-03-3D-3E-04
### CRC32 Step value, crc: 1757713094 offset:40 size: 20 packetLocalNo:2
Sent data: 94-4D-55-01-D7-9D-61-77-7A-38-D9-2B-CE-0C-0D-B8-EC-6E-6A-C9
### CRC32 Step value, crc: 3411050851 offset:60 size: 20 packetLocalNo:3
Sent data: 38-E5-26-6F-DB-48-00-10-00-1A-40-63-5D-94-C5-85-06-B2-6D-2E
### CRC32 Step value, crc: 2163882705 offset:80 size: 20 packetLocalNo:4
Sent data: 0E-D2-AA-3A-47-C3-1D-27-1C-53-A2-F1-80-C7-03-8E-AB-9E-85-FE
### CRC32 Step value, crc: 784168122 offset:100 size: 20 packetLocalNo:5
Sent data: 46-03-88-C0-59-25-5E-B4-57-86-ED-00-60-74-A8-08-AA-F1-7A-19
### CRC32 Step value, crc: 1327207369 offset:120 size: 20 packetLocalNo:6
Reading 15 bytes from file stream
Sent data: FD-32-02-C8-55-E4-79-E5-2B-54-4A-DA-0C-E9-BD
### CRC32 Step value, crc: 4151597504 offset:135 size: 15 packetLocalNo:7
End of data transfer
Begin read checksum (sending 03)
Control point notif data: 60-03-01-00-00-00-00-00-00-00-00
Check Sum Response 60-03-01-00-00-00-00-00-00-00-00
End read checksum
Checksum received (Offset = 0, CRC = 0)
CRC does not match!
nrf52832, SDK v12.3.0, iOS
