Zigbee HA Atrribute Reporting
Hi, I'm trying to setup attribute reporting on zigbee HA, the device role is ZB_ZCL_CLUSTER_SERVER_ROLE, I want to configure reporting for cluster 0x0006, so each time I flip a switch it send clusters current state to the coordinator, none of the examples seemed to be configured for reporting.
Does it has to be explicitly configured/enabled on the node?
Thanks in advance.
  • Found this in internal FAQ page:
    Do we have a ZCL attribute reporting example
    We do not have an example created specifically to demonstrate attribute reporting, although:
    • From server/advertiser site: for every cluster there is a set of attributes, that shall have attribute reporting implemented and available. As a result, a simple light bulb example may be used as reporting ZCL server.
    • From client/subscriber site: all commands required to configure reporting and logic to parse reports were added to the CLI Agent Router example.
    Combination of those two gives a complete "reporting" example.
    Additionally, the CLI uses a "raw" technique of intercepting ZCL reports. There is also a dedicated ZBOSS callback, that may be used to get ZCL attribute reports, but it was not used, as there might be only one reporting-callback defined.
    Steps to test ZCL reporting:
    1. Flash light bub example to one board
    2. Flash CLI example (Zigbee CLI Agent example) to another board.
    3. Use CLI as the coordinator:
      1. bdb role zc
      2. bdb start
    4. Find the light bulb's endpoint, short and long addresses:
      1. zdo match_desc 0xFFFD 0xFFFD 0x0104 1 0x0006 0
      2. zdo ieee_addr <returned_short_address>
    5. Create binding FROM the light bulb TO the CLI ON the light bulb:
      1. zcl bind <bulb_long_addr> <bulb_ep_from_match_desc> <CLI_long_addr> <CLI_endpoint, defaults to 64> 0x0006 <bulb_short_addr>
    6. Subscribe for attribute's changes:
      1. zcl subscribe <bulb_long_addr> <bulb_ep_from_match_desc> 0x0006 0x0104 0x0000 16
    Magic numbers:
    0xFFFD - broadcast address, all devices with RxOnWhenIdle == 1
    0x0104 - Home Automation profile ID
    0x0006 - On/Off cluster ID
    0x0000 - On/Off attribute ID
    Hope this helps!
    Best regards
    Bjørn
  • Why use "bind on ",before "subscribe "? Do "subscribe" depend on "binding"?
  • I think that you should be able to subscribe to the attribute change without having to bind two endpoints prior to calling zcl subscribe.
