It appears to be an error in the function signature `sd_ble_gatts_hvx()`.
Since the call is made via software interrupt, the const qualifier is cast away regardless.
So, most likely this is just a form of documentation error?
Please confirm, thanks.
Interesting topic.
Provided that the object pointed to does not change memory location, the compiler will accept this. Although, still a bit confusing with the const qualifier for struct pointers in C.
Here's an example.
OK: *p_hvx_params->p_len = 0;
Not OK: p_hvx_params->p_len = 0;
Håkon
For example (code snippet):
uint16_t const length = 4u; hvx_params.p_len = &length; uint32_t error_code = sd_ble_gatts_hvx(&hvx_params); *hvx_params.p_len = ??
The comments say that p_len's pointed to value may by changed by the call (perhaps the buffer did not allow for enough space?) . But p_len is a const pointer.
Looking for clarification here: Will the returned value of p_len be different than the value passed in? Ever?
*p_len value can be altered by the softdevice, as per the API documentation:
@param[in,out] p_hvx_params Pointer to an HVx parameters structure. If @ref ble_gatts_hvx_params_t::p_data * contains a non-NULL pointer the attribute value will be updated with the contents * pointed by it before sending the notification or indication. If the attribute value * is updated, @ref ble_gatts_hvx_params_t::p_len is updated by the SoftDevice to * contain the number of actual bytes written, else it will be set to 0.
You can therefore set the value by de-referencing "*p_hvx_params->p_len=1234;", but not change the actual RAM location it points to.
Håkon
