I am using an NRF52832 on a Custom Board that i built myself.
I want to communicate with a PC software via UART so i've connected the TX, RX and GND ports to the USB port on PC using a TTL-232R-3V3 cable (an FTDI chip is built in it so that it should normally transform the Uart Signal to USB (Serial)) .
I've used the app_uart_fifo.c as application layer for uart and the nrf_drv_uart.c as the Driver and it worked with an nRF52832 on a SDK but not on my Custom Board.
I debugged and i have found that my program is stuck in the While Loop (in nrf_drv_uart.c) waiting for the TXDRDY Event to be generated.
Like i said it works fine with the SDK and the included USB cable but not with my own Configuration and i don't undestand why !
I have tested plenty of different Solutions and configurations such as Debugging the SDK where i found that it goes over UARTE and not UART so i tried this on my custom Board but then it stuck on the While Loop of the ENDTX / TXSTOPPED Event !
Thanks for your Help !!
